03-15-2012, 05:18 PM | #1 |
Drives: 2011 2SS Join Date: Mar 2012
Sport Mode tranny tuning
Howdy, I just had my A6 2SS tuned after full bolt-ons were installed and the shift band in Sport Mode is taking some getting use to. Its shifting out of 1st and 2nd gears around 5500rpm and is definitely not suitable for casual driving. I don't really have a problem with it since it is Sport Mode and I use Drive for normal driving, but can someone tell me if this is a normal tune for Sport Mode? It seems like the way this is tuned is meant for drag racing.
03-15-2012, 07:02 PM | #2 | |
www.jannettyracing.com
03-15-2012, 07:05 PM | #3 |
Drives: 2011 ss camaro Join Date: Aug 2010
10/28/2010 got it
03-15-2012, 07:08 PM | #4 |
k.. what rpm the should the lower gears be shifting at in Sport Mode after a tune with full bolt ons?
03-15-2012, 07:18 PM | #5 | |
Linear, light throttle low MPH shift, heavy Throttle High MPH shift.
03-15-2012, 08:50 PM | #6 |
White 2ss, LT, CAI, Tune
Drives: 2010 L99 Join Date: May 2011
U NEED Ted tuned my car, and my S mode is nothing like that at all... S mode is just that a little sport compared to to Drive. shifts firmer and I can drive my car in eather D or S. it shifts out just fine. your car should not be doing that....
03-15-2012, 08:59 PM | #7 |
U need a new tuner
03-15-2012, 10:04 PM | #8 |
Drives: 1999 Trans Am Join Date: Jul 2009
You can set it any way you want. The tuner should of asked you what you would like.
03-15-2012, 10:10 PM | #9 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
are you saying your 1st and 2nd gear shift releases at 5500 RPM under 50% throttle in light traffic driving ?
your tuner would have to raised your shift points at part throttle about 20 additional MPHs for that to happen. I raise my shift points 2-3 MPH at < 50% part throttle to put it in perspective. Bring it back and tell them your have a issue |
03-15-2012, 10:13 PM | #10 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
I drive my car in "S" mode all the time. It depends how aggressive you are on the gas. If I go from a stoplight and just leisurely accelerate, it will shift fairly low in the RPMs. However, if I give it a lot of gas or go WOT, it will shift around redline
03-15-2012, 10:14 PM | #11 |
thats how its supposed to work
03-16-2012, 01:18 AM | #12 | ||
I'll talk to them tomorrow and stick to the taps and Drive for now, which function fine. The shops been helpful and Im sure wont have a problem making it right. |
03-16-2012, 09:22 AM | #13 |
There are 3 different tables that dictate "shift patterns", one of which is how the car shifts in Sport mode.
This is what a tuner sees on a stock tune in HP Tuners: The numbers in the table are the speed in MPH when the shift occurs. Just thought I'd post this so you could see what stock is, and see what exactly is going on from the tuner's point of view too. |
03-16-2012, 09:48 AM | #14 | |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Your transmission should shift at a fairly low rpm under light acceleration. As you increase your acceleration, your shift points will move up the tach. Then at WOT, your shifts will be up near redline. |
Thread Tools | |
Similar Threads | ||||
The best priced Tuner. Tampa Tuning | Tampa Tuning | Sponsor Announcements / Giveaways / Contests | 4 | 04-07-2012 08:58 AM |
VIDEO Proof: 2012 Camaro ZL1 Takes on Nurburgring in 7:41.27 | IOMZL1 | Camaro ZL1 Forum - ZL1 Specific Topics | 181 | 11-26-2011 04:20 AM |
Camaro ZL1 Laps Nurburgring in 7:41.27. Enters Supercar Territory!! | Tran | Camaro ZL1 Forum - ZL1 Specific Topics | 547 | 11-15-2011 01:53 PM |
Am I the only one who is disappointed? | 91Z28350 | Camaro ZL1 Forum - ZL1 Specific Topics | 136 | 10-27-2011 12:01 AM |
Camaro does the Nurburgring test track in 8:20 | 2sharp | 5th Gen Camaro SS LS LT General Discussions | 45 | 07-23-2008 03:17 PM |
