04-05-2012, 08:05 PM | #1 |
Procharged
ABS, Brake and Stabilitrack
Anyone experience their ABS, Brake and stabilitrack light on at the same time? No codes present. Never had issue before.....just finished install of supercharger, now this happened. Guess I'll check wires, but never touched brakes. Didn't happen until after I drove it for a couple of days.
2010 ABM RS/SS with a Procharged LS3, Flowmaster exhaust. |
04-05-2012, 08:49 PM | #2 |
Check the fuses. Typically more than 1 system runs on a fuse, so if it blew, its going to throw lights for everything tied to it. Im not at home right now so I cant give you the exact fuse, but Im sure its one of the ones under the hood. Just look on the undercover guide.
2010 Camaro SS
04-05-2012, 09:54 PM | #3 |
Procharged
No blown fuses, I did however pull the ECM fuses and then restarted the car. It seemed to clear what was there. Just seemed kind of weird....I drove car to pick my son up from school, came back to car, started it up and saw the three lights on with the park assist message on the DIC.
04-06-2012, 08:19 AM | #4 |
Drives: 2010 camaro Join Date: Mar 2012
when my stabilitrac came on i had a plug wire loose from a header install. the car ran better but was still missing so, i pulled all spark plugs and one was cracked in 3 places. replaced the plug and all the lights went off and car ran like a champ. this might not be the case with yours but you just did an install so triple check your work and all areas wher you could have knocked or bumped something loose
Thread Tools | |
Similar Threads | ||||
brake upgrade for 2LT non-rs | khabboub | Suspension / Brakes / Chassis | 25 | 01-30-2011 09:48 PM |
