Old 04-06-2012, 05:34 PM   #1
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
UP IN A CLOUD OF SMOKE UPDATE!!! NOT GOOD
I figured i would take some more pics of inside cylinder #5. I was able to manipulate the camera to get more shots and this is what i see. This was not in the original post of up in a cloud of smoke conclusion. Looks like part of the piston is gone....where did it go, down in the oil pan i guess, but how did it make it past the rest of the lower ring lands?
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 04-06-2012, 05:47 PM   #2
ParkerB57
COTW 11/12/12
Drives: 1SS RS IBM
pull the heads,ony way to have a clear idea of what happened
ParkerB57 is offline   Reply With Quote
Old 04-06-2012, 06:00 PM   #3
BullF-16
BullF-16's Avatar
I am trailering the car down to Dallas once my LSX motor is built and need the car to be able to run to get it on the trailer. Then we will break down this motor and figure out what happened. all the other pistons/cylinders look good, just #5.....bad injector???
Believe it or not, the car runs fine as is, just has erratic AFR readings, no noises, vibrations etc. Will not run it again till time to drive it on the trailer
Old 04-06-2012, 06:14 PM   #4
2SSLincolnSS2
SoCal
2SSLincolnSS2's Avatar
Drives: 2011 SS2
Most of the piston melted away IMO. I had a buddy run his boat for a whole weekend with it blowing oil out of the breathers (supercharged BB).
Ran fine (a little rough and down on power) right up on to the trailer (at the end of the weekend), pulled plugs, found oil on a 2 of them and took it home. Pulled the motor apart a couple weeks later and found 2 of the pistons melted.
The CC looked fine, pieces weren't bouncing around.
2SSLincolnSS2 is offline   Reply With Quote
Old 04-06-2012, 06:19 PM   #5
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
yup just melted it unlike detonation where it breaks it apart and bounces around everywhere
xx_ED_xx is offline   Reply With Quote
Old 04-06-2012, 06:34 PM   #6
BullF-16
BullF-16's Avatar
Wow, what would cause it to melt. I understand detonation, and the metaphor of taking a hammer to the pistons. but just this one cylinder, part of the piston melts, what would cause this. Seems maybe a complete lack of fuel to this particular cylinder?
Old 04-06-2012, 06:37 PM   #7
SC2150
LincolnSS2 has it right. It melted away and went out your exhaust valve through the exhaust. If you have cats you will see the melted debris stuck in them.
Old 04-06-2012, 06:40 PM   #8
garcmol
garcmol's Avatar
Bull, I wouldn't even start that car any more. This is like plaque in your arteries right now. One piece breaks off, it'll take more than just resleeving!
Old 04-06-2012, 06:51 PM   #9
BullF-16
BullF-16's Avatar
Im thinking a very lean condition in this cylinder alone. Can only think of a bad/faulty injector. I do need to run it again to get it on the trailer but will only be at idle for a couple minutes.
Something got really hot in here and i am lucky it just vaporized and went out the pipes. If it broke off, i would have been walking home.
Anyone experts out there know what could have caused it. I am pretty sure it was not the tune. The evidence so far just doesnt point to that.
Old 04-06-2012, 06:59 PM   #10
2SSLincolnSS2
SoCal
Drives: 2011 SS2
Well just like supercharged carburated motors, if it's lean it'll take out the weakest first and not necessarily all of them. At the same time with carburated / open manifold some cylinders may get more fuel / different charges.
Not sure on this motor...
Old 04-06-2012, 07:55 PM   #11
BullF-16
BullF-16's Avatar
here's me thinking out loud, not melted but from scaling this piece of piston that is missing, it looks to be about an inch or less of a chip. Could it have broke off and been evacuated out the exhaust valve. The pics magnify everything but if you scale the missing piece it almost looks like it could have been chucked out the back end. No cats and no mufflers on my exhaust, just some dimples poked in 3in pipe that stainless works monikers it as a "retro" exhaust.
Look at how sharp the edges are on the missing piston, if it was melted it would be rounded off, not sharp/jagged like the pics shows.
What say the experts?
Old 04-06-2012, 10:03 PM   #12
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Drives: Silver Ice 2010 SS/RS A6
CAST piston + BOOST +BOOST+CAST piston = carnage...and not enough injector.
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
LSX-80MM is offline   Reply With Quote
Old 04-06-2012, 10:07 PM   #13
jrpxxii
jrpxxii's Avatar
When my motor went it blew one of my heads apart and spark plugs were eaten. All of it went thru the motor and out the rear. Its amazing how a motor can eat parts and shoot them out the exhaust. I look at it as a positive because now you get a kickass LSX motor.
Old 04-06-2012, 10:21 PM   #14
2SSLincolnSS2
SoCal
Drives: 2011 SS2
I recall Mr. Jannetty saying something about larger injectors even though yours weren't at full duty cycle.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
RESONATORS DELETE UPDATE AND AIRAID CAI VR Baron Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 4 12-23-2010 07:29 PM
Edmunds.com review of Holden Commodore... good info. LSxcellent General Automotive + Other Cars Discussion 6 07-23-2007 07:49 PM
