04-06-2012, 10:31 PM | #1 |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
ADM scoop question
When using the ADM scoop is it necessary to relocate the windshield wash fluid to a new location? I probably would, but just wondering if anyone has put one on without doing it.
04-06-2012, 10:42 PM | #2 |
CamaroFans.com
Yup... the stock bottle has to come completely out...
04-06-2012, 11:49 PM | #3 |
Drives: '69 SS Convertible Join Date: May 2009
Yes. The washer bottle has to go. Not only will it not fit but even if it did you would be blocking the air flow which would defeat the purpose of the scoop.
Good thing is that since you have a R-F intake they make a really nice, stock looking replacement that attaches the around the back of the heat shield. You need to look into getting that one.
Build Journal |
04-07-2012, 05:20 AM | #4 |
+1 There are several options available for replacing it though. Lots of info here.
04-07-2012, 05:46 AM | #5 | |
Philippians 4:13
04-07-2012, 09:58 AM | #6 |
If you want to go cheap and light weight you can make one like I did for about $20.
http://www.camaro5.com/forums/showth...light=halltech
Build Journal |
04-07-2012, 11:13 AM | #7 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Apex has one for $70, attaches to the scoop. I used that with my Halltech as the RF one wount work with it.
04-07-2012, 12:30 PM | #8 |
CamaroFans.com
Maybe in Michigan you might use the washer fluid from time to time, but I really never missed not having it. It just messes up a clean and polished car too. Weight savings is also nice.
If you must have one Apex Chase linked to the best one especially if you like a nice clean looking engine compartment and don't want some cheap looking plastic bottle in there. |
04-07-2012, 03:34 PM | #9 | |
04-07-2012, 05:15 PM | #10 |
I bought the apex kit that bolts to the scoop, its nice but I have a garage queen and won't ever use it.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir 1989 Silver 5.0 Mustang LX Coupe 1999 Pewter Tahoe LT 2011 Blue Camry SE |
Similar Threads | ||||
Roto Fab Washer Bottle kit and ADM Air Scoop | bajamoon | Local Marketplace | 12 | 06-28-2014 06:18 PM |
2010+ Camaro V6/V8 Roto-Fab Washer Reservoir Relocation Kit & ADM Performance Scoop! | AutoAgenda | V8 Bolt-Ons & Tunes | 39 | 08-10-2012 01:41 PM |
Does the ADM Scoop throw much dirt and dust on filter? | Lee123 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 02-18-2012 12:30 PM |
2010+ Camaro V6/V8 Roto-Fab Washer Reservoir Relocation Kit & ADM Performance Scoop! | AutoAgenda | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 5 | 08-05-2011 09:23 AM |
Just installed the ADM Intake Scoop | InvaderMoose | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 25 | 03-17-2011 10:26 PM |
