04-07-2012, 10:34 AM | #1 |
Drives: SS camaro Join Date: Apr 2011
Converting Raw OBD2 Data
Anybody know of a tool to convert the raw data (voltages, etc.) to actual numbers, temperatures and pressures?
donald |
04-07-2012, 12:18 PM | #2 |
No Tags/Habitual Violator
Drives: 2012 SIM 2SS/RS & z71 Join Date: Sep 2011
What do you have now? Ipad, Droid, files of obd2 data?
Assuming you have not logged any data yet, you can use a Dashdaq (Drew Technologies) that logs and displays a few gauges. Built like a navigation device and plugs into the odbc connector. Not as cool as those wireless Ipad & Droid products, but probably more precise. Also SCT makes a handheld unit can integrate a laptop to the obd2 for data logging and reporting. It's also useful for loading new tunes. |
04-08-2012, 01:25 PM | #3 |
How about a sample from SCT Live Link
Intake air temperature data ranges from 29 to 48, since is 80+ degrees in Houston those are actual temperature, how do I convert them to degrees F? Engine coolant temperature ranges from 90 to 90.1, same comment as above how do I convert to degrees F. Accel pedal position ranges from 19.21 to 82.71 how do I convert to percent open position? Ignition timing advance ranges from -4 to 52 how do I conver to degrees advanced? donald |
04-08-2012, 01:31 PM | #4 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
04-08-2012, 07:41 PM | #5 |
Why would I spend money to get the data I already have. I would believe one if the many smart folks on this forum have the information. Im not looking for a different way to get the data just the right way to interpret it.
Donald |
04-08-2012, 08:21 PM | #6 | |
The Celsius to Fahrenheit, just use an online calculator. As for those other values, the pedal position numbers you have are the percentages, and the timing numbers are the degrees. Nothing to convert. |
04-08-2012, 09:27 PM | #7 | |
So in the end you will have two columns of the same channel - the original and the new one converted. I have done this for temperature but not for throttle. Seems there was another channel that reports 100% |
Similar Threads | ||||
iPhone/iPad tracking your location... | Brokinarrow | Off-topic Discussions | 18 | 04-28-2011 06:58 AM |
SCT Data Link Data Logging | ParisTNDude | Tuning / Diagnostics -- engine and transmission | 3 | 03-17-2011 11:02 PM |
For sale-Snap-On MT2500 Scanner 80s obd1 to 2008 Obd2 EOBD2 | Seneca SS | Audio / Visual / Electronics/ Gauges / Nav | 0 | 08-24-2010 09:02 PM |
ls3 ss now 430hp!!!? | gss9909 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 57 | 11-18-2008 01:56 PM |
