Old 04-12-2012, 08:42 PM   #1
TCAT
TCAT's Avatar
Drives: Has Wheels
Question What is the maximum power capability of 630cc/min fuel injectors?
The complete Turbonetics kit includes 630cc/min fuel injectors (I believe this converts to 60 Ibs/hr), which I used in my build. However, I am about to get my car retuned for more power. What power level is maximum for that size injector.
Now, I in no way want to max these injectors out, so I'm looking at purchasing more capable injectors. This will a least give me room for future power upgrades, but larger injector capability also gives me piece of mind that I'm not using them at maximum duty cycle. Can you recommend what size injectors I should look into for 600+ rwhp applications, and which manufacturer of the injector to buy. I remember reading that Ted Jannety recommended Injector Dynamics ID-850. Anyone have experience with those or any other similar injector?
Thank you!
TCAT is offline   Reply With Quote
Old 04-12-2012, 08:51 PM   #2
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Fuel injector connection check them out. They also have a formula chart on their website that will tell you what injector you need for the hp your running just punch in the numbers.
JLE58 is offline   Reply With Quote
Old 04-12-2012, 08:52 PM   #3
TCAT
TCAT's Avatar
Drives: Has Wheels
Excellent, thanks a ton. I'll have to look them up right now. Thanks again!
Old 04-12-2012, 09:04 PM   #4
TCAT
TCAT's Avatar
Drives: Has Wheels
Ouch, I just checked out the Injector Dynamics 80 lb/hr injectors, and unfortunately they are just too expensive for me. They are over $900.
Any other injectors around the 80lb/hr capability that are still good quality and reliable, but a bit more cost friendly?
Old 04-12-2012, 09:11 PM   #5
JLE58
fuel injector connection. Is much cheaper then injector dynamics. http://fuelinjectorconnection.com/sh...d&productId=19
Old 04-12-2012, 09:16 PM   #6
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
or these for $550, will give you plenty of room to grow.
http://fuelinjectorconnection.com/sh...&productId=211
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 04-12-2012, 09:16 PM   #7
JANNETTYRACING
JANNETTYRACING's Avatar
I sell them for under 900 call me
I would not go any other way.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 04-12-2012, 09:17 PM   #8
JANNETTYRACING
These are Ford injectors that are too tall and do not have the correct orings.
Old 04-12-2012, 09:20 PM   #9
JLE58
You call them and tell them what your going to use them for and they send the correct injectors for what ever motor your running. I believe thats just a generic page.
Old 04-12-2012, 09:26 PM   #10
BullF-16
BullF-16's Avatar
Ted, how will the ID2000s do in an LSX 427 at about 800 RWHP drive ability wise for about a year until i upgrade to an F1X and about 1000 RWHP. I dont think the ID1000s will be enough for my final goal. Just want to make sure there wont be issues with the humongous ID2000s on 800RWHP and dont want to have to buy new injectors with the big blower
Old 04-12-2012, 09:29 PM   #11
BullF-16
BullF-16's Avatar
93 octane pump gas BTW
Old 04-12-2012, 09:36 PM   #12
BullF-16
BullF-16's Avatar
TCAT. drop an email to Jon at info@fuelinjectorconnection.com He will answer your email within 10 minutes. Pretty impressive actually. Just tell him your plans and he will tell you what you need.
Sorry, that link doesnt connect you to outlook. but that is the email address he will respond to
Old 04-12-2012, 10:05 PM   #13
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
i spoke with ted awhile back and the id850 is 1226hp at crank at 80% duty cyle, so depending on dt loss. do the math..i would figure 20% a good start
mikepage0007 is offline   Reply With Quote
Old 04-12-2012, 10:43 PM   #14
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
I learned a lot from my Buick with injector swaps. Different brands/styles of injectors will act different...even if same rating. Always ask our tuner the 'which injector' question. Even though the IDs are high as hell (I agree), if your tuner prefers them, go with it.
-John S.
JRE FUEL SYSTEM UPGRADE EDELBROCK SUPERCHARGERS JANNETTYRACING Forced Induction - V8 91 05-11-2011 11:35 AM
Edelbrock S/C and Fuel Injectors? gtc352 Forced Induction - V8 10 04-01-2011 10:14 PM
GM Reveals 2012 Buick LaCrosse with eAssist: 37 MPG Highway FenwickHockey65 General Automotive + Other Cars Discussion 40 11-18-2010 06:48 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
