04-23-2012, 09:23 AM | #1 |
Drives: '69 SS Convertible Join Date: May 2009
Who has used the Raptor Dual Mode shift light?
Curious to hear any feedback about this shift light.
I'm wondering if this wouldn't be a good mod to help get a better more consistant launch and more consistent shifts for a better ET.
Build Journal |
04-23-2012, 09:53 AM | #2 |
Drives: 2010 2SS and 2011 LS Join Date: Aug 2011
Hi caverman, what timing you have. I just took my car to the track yesterday for the first time since installing the Raptor shift light. I really like it, as for getting more consistant launches I'll need some more passes to get a good read on that. The thing I really like is the fact that I don't have to keep looking from the tach to the tree to make sure my launch rpm is where I want it, the light is plenty bright enough that I can just watch the tree while seeing the light indirectly. Yesterday I was launching from 2400 to 2600 rpm, trying to find the sweet spot, as for the shift point I had that set at 6100 but with the shifts you can either go with the light or the tach, I don't shift at the same rpm for each shift, I short shift 1st a little and stretch 3rd out a little longer. Bottom line, the Raptor is a great addition for me I'd recommend it for sure.
Around here we like baseball, hot dogs, apple pie, and Chevrolet
04-23-2012, 10:11 AM | #3 |
How did you attach it to your dash?
Build Journal |
04-23-2012, 10:13 AM | #4 |
Brandon Gilpin
Drives: 2011 Camaro SS / 2014 Fiesta ST Join Date: Dec 2011
and how hard is it to install?
2011 Camaro 1SS Platinum ed. ls3 k&n CAI, BBK LT's, MBRP Cat Back, Vengeance Racing Kaotic Camshaft, Melling oil pump, Norris Catch Can, dyno tuned By AGP Speed & Custom, msd coils, taylor cables, Vmax ported throttle body, strut brace, eibach springs, hurst ST shifter.
Black on black, Private forged wheels, Oracle side marker lights, black tail light bezels, 3D Carbon body kit |
04-23-2012, 12:08 PM | #5 |
I siliconed the clip to the dash so if I ever want to move or remove it the silicone will come off no muss no fuss, I ran the wire harness between the A-pillar and the dash and then down into the fuse box area and under the dash. As for the difficulty of installation that depends on what your capabilities are. There are 4 wires to hook up 2 are just the power and ground. The other two I hooked up to the 2 ECM harnesses (x-1 and X-2) there is a great video on here to show you just how to do it. The entire install took me less than an hour.
04-23-2012, 01:52 PM | #6 |
Is there a way to turn it off? I'm just thinking that in normal driving where you would hit that 2600-2800 rpm and having the light go off all the time might get annoying after while.
I'm wondering if I can get a 4 wire plug (like a trailer light plug) that I could use to plug it in at the race track. Then maybe use a phone or GPS suction cup that I could mount it to. When I'm at the track just plug it in, run the wire up the side of the dash, and then suction it to the front windshield.
Build Journal |
04-23-2012, 01:56 PM | #7 |
I don't see any reason as to why that wouldn't work. You can shut off the launch mode, and it comes with a soft rubber cover for the light so you don't see it come on in normal driving.
04-23-2012, 02:09 PM | #8 |
M6 9 second club
Drives: A 4000 Lb BeaSSt Join Date: Jul 2009
I was one of the first ones that installed one in a 5th gen and went through all the trials of getting it to work properly. They have since re-designed it which makes for easier install and easier to adjust the settings.
Its an awesome piece and works great. And as far as the "launch" light coming on during normal driving, it doesnt happen. One of the 2 wires that connects to the ecm is a speed sensor feed. If the car is in motion, the "launch" function is completely disabled. The only time it will come on during normal driving is when you start the car it goes through a test sequence of lighting up which lasts about 2 seconds.
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff #BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning Check out my youtube channel: http://www.youtube.com/user/6410Jrod Follow me on Instagram: @J_Rod6410 |
04-23-2012, 02:16 PM | #9 |
You guys don't by-chance know a good place to order one of these from, do you?
04-23-2012, 03:26 PM | #10 |
M6 9 second club
I got mine from Kentucky Speed--kyspeed.com-- a couple years ago. Not sure if they're still a sponsor here but I'm sure other vendors also sell them here.
04-23-2012, 03:29 PM | #11 | |
Drives: 2012 2SS M6 Join Date: Dec 2011
2012 2SS Convertible
Magnuson, Headers, Cam, JRE Tune. 563 HP. |
04-23-2012, 03:50 PM | #12 |
WICKDSS
Drives: 2011 1SS/RS IOM LS3 Join Date: May 2010
I just installed mine (a Gen II Dual Mode) a few weeks ago in hopes to being more consistent also. Haven't had it to the track yet. I mounted mine down by the 4 gauges on the drivers side. Seems to be visible to my peripheral vision even with a full face helmet on. The best place to order is http://www.apex-speed.com/raptor-per...t-rap2000.html
I mounted mine to an old ProCLip phone mount I had. Still on the fence on whether I want to move it up to the A pillar or not. My plan is to add a plug to the cable right behind the light to make it removable when not needed.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei 11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds. |
04-23-2012, 04:09 PM | #13 |
Burning up tires
Drives: 2023 ZL1 Vert Join Date: Jul 2010
I love my raptor dual mode shift light!
04-23-2012, 04:10 PM | #14 |
I'm sorry Lee123 I misspoke it isn't a video rather a diy with pics, here ya go.http://www.camaro5.com/forums/showthread.php?t=60745
