![]() Drives: 2010 Silver 1LT/RS Join Date: Apr 2012
PROBLEM WITH 4 GAUGE
I just ordered a used four gauge cluster out of an SS and I'm trying to put it in my 2010 1LT/RS. All the threads I read said it's plug and play. It's not lighting up at all and I think I have a the necessary equipment for it. Here are the picture with the gauges and wires.
![]() Drives: 2012 1LT-RS Join Date: Jan 2012
I just installed mine yesterday. Make sure all of the connectors snap in and are tight. If still problem persists, make sure all of the pins in the male connectors are straight...sometimes they get bent and do not connect.
Upgrade fever
Drives: V6 Join Date: Dec 2010
Your pictures are not showing. And yes it should be plug and play. I purchased one for myself and it work right away. Is yours new or used?
F-4E Phantom-57th AGS Phantom AMU
Upgrades--RX catch can/Leather steering wheel/leather shift knob/4 pack gauge cluster/Painted stripes/Painted Bowtie's/Technostalgia tail lights/ZL1 spoiler/Painted steering wheel bezel/Painted speedometer bezel/Duel Halo's/Transformers Front Fascia Blackout ![]() |
http://imageshack.us/photo/my-images/513/img5331h.jpg/
http://imageshack.us/photo/my-images/805/img7085g.jpg/ I bought it used from eBay |
Upgrade fever
Hopfully you will not have to contact the seller. So check the pins to make sure they are not bent as was just suggested. If thats not the problem its time to break out the multimeter to see whats going on.
#6 |
TC works along with car charger
#7 |
Upgrade fever
With the Multimeter check both the gauge cluster connections and the connections on the car.
#8 |
You need a harness that plugs into the passenger side console. I have the same problem and was told to Ordered the harness from Casperelectronics should be here monday
#9 |
COTW 5/27/13
This is your problem. there is a harness that plugs in @ the Ebrake handel that give the cluster its power. Do you have the harness? if not i could help you further trouble shot the problem just let me know if you need help
622RWHP/512FTLBS on 91 octane 2.9l Whipple 4" pulley. Vengance VRSP3 cam. Lots of BMR & AAC. Body work by Gary's Customz. Nic D tuned My build thread |
#10 |
Hey dcc1464 and Jermola23,
Thats the problem! I didn't plug anything where the e-brake is. Where is the best place for the harness?? |
#11 |
Yup the harness goes there. Southerncarparts.com they have it there
#12 |
can i get a direct link Jermola?
#13 |
i think i found it!
#14 |
YUDLOSE
Drives: Supercharged 2010 ABM 1SS Join Date: Aug 2011
gmpartshouse.com has them as well. Its about $60.
Trey Jenkins 2010 Supercharged ABM SS Camaro LS3 #400 Order Number: NJGC85 Build Date: 06/24/2009 1996 Blue Z/28 Camaro 396 stroker in the process 1994 Red Z/28 Camaro |
