Old 04-30-2012, 01:20 PM   #1
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
my friend listened to autzone and used turtle wax rubbing compound...
well about a week ago a friend of mine found a scuff on his bumper, so he went to auto zone and asked what he should use. they told him to use the turtle wax rubbing compound...errr what a mistake,,it left the spot worse then it was before...so once i found out about this, i offered my help to fix the
problem with my knowledge on detailing i was sure id be able to get it fixed
,,i have alot of adams stuff so thats what i used along with the porter cable 7424,,, first i used adams fine machine polish on the bigger pad,,that pad was to big for the spot. so i went ahead and used the 4 inch adams pad..the fmp and white 4 inch bad..made it look better but did not do the job,so i switched over to adams swirl and haze remover and the orange 4 inch bad..i did one pass with it and it made it look much better. but stil wasn't happy with it fully, so i did a couple more passes with the shr and..that did the trick...it was fixed! i followed up with adams fine machine polish again along with adams machine sealant.. it looked brand new...the car is a daily driver so it has rock chips on it,,but here are the before and after pics!
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 04-30-2012, 02:28 PM   #2
pecoman
Drives: 2010 rally yellow 2ss rs
Nicely done, you should be proud and your friend owes you, big time!
pecoman is offline   Reply With Quote
Old 04-30-2012, 03:12 PM   #3
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
compound didnt do that looks like u sanded it or had dirt in ur buffer
u couldnt of buffed it with turtle wax compound cause the lines are straight in the scratches like someone sanded it
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 04-30-2012, 03:31 PM   #4
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
umm why would i make this up? he told me he used turtle wax compound to take out a scuff
..so as far as im concerned im going with he used compound to make that mess. I DID NOT USE compound to get that out..nor did i use sand paper..im no idiot..he used the compound and rubbed back n forth creating those scratches.and no i didnt have anything in my buffer pads. as i clayed the bumper before.i did anything ..and the pads were brand new right out the package
Sent from my SCH-I510 using Tapatalk 2
Old 04-30-2012, 04:05 PM   #5
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
..so as far as im concerned im going with he used compound to make that mess. I DID NOT USE compound to get that out..nor did i use sand paper..im no idiot..he tool the co.pohnd on a bad and rubbed back n dorth creating those scratches
Anyways...good job..he definitely owes you a few beers or some dinner or something!
LS3 SS is offline   Reply With Quote
Old 04-30-2012, 04:43 PM   #6
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
i dobt get some people..why would i use rubbing compound for that and use sandpaper on my car for no reason
Old 04-30-2012, 09:17 PM   #7
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
u tell me thats what it looks like to me ive buffed cars for 6 -7 years professionally for 100 bucks a wack and must be doing somethign right cause i could do it all day long if i wanted to but i dont like doing it but 2 - 4 a week. if that . im just sayin looks like he used something other then just compound to me. dont get mad hell im just sayin .
u said so urself he took turtle wax to get the scratches out so turtle wax didnt do it then
Old 04-30-2012, 09:22 PM   #8
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
compound is what u use to cut the clear coat and remove scratches in ur clear coat or if u have enamel paint to remove the paint to smooth it out u can use wax or whatever just takes alot longer. then use finesse or , hand glaze . im not sayin nothing bad i just know the worst compound out there isnt going to do that alone. u did a good job cleanin it up. u talkin me all wrong.
Old 04-30-2012, 09:25 PM   #9
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
Don't sweat it bro, the dude's got like 3 brain cells, can't understand him most of the time .....On to better things, you did an awesome job fixing his f**k up. I love Adam's products & the PC, you use those and you rides look top notch for life! Good job!
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 04-30-2012, 09:38 PM   #10
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Wasnt mad bro.. JUst sayin he used the turtle wax compound..he even gave it to me once i fixed cuz he sisnt want it..he said nothing sand paper..so he must of rubbed pretty hard...u may know what ur talkin bout but im just tellin what he did to cause this
Old 04-30-2012, 10:48 PM   #11
David79z28
David79z28's Avatar
Drives: 79Z28 and 2010 2SS/RS
Rubbing compound dulls paint. He also didn't say what it was applied with. Your friend started too aggressive.
You did a great job by stepping up the aggressiveness of the materials until the damage was removed, then polishing it out.
David79z28 is offline   Reply With Quote
Old 04-30-2012, 10:57 PM   #12
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
Awesome Camaro save dude !
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 04-30-2012, 11:42 PM   #13
CookieCk
Drives: 2012 Camaro SS
I've used turtle wax before on a few vehicles, the stuff worked just fine for me. Not trying to say it's better then what you did by any means, but I don't think it was just what your friend used that caused the problem, maybe how he was using it? Great job though.
CookieCk is offline   Reply With Quote
Old 05-01-2012, 05:49 AM   #14
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
The paint was very dull..good question on what did he used to apply it with i would have to fi.d out..but i thibk it.came with a pad and he just kept rubbing it with the compound
Thanks!
