05-06-2012, 09:20 PM | #1 |
Always Lookin
Drives: 10 SS/RS 6M Blk/Blk Silver Stripes Join Date: Aug 2010
Kooks Drone!!
I have a full Kooks exhaust system and it drones pretty bad at around 1800-2100! Its really bad!! Has anyone installed J-pipes on their KOOKS system? If so please let me know your results and could I please get your J-pipe dimensions!!
-Custom grind Crane Cam with 3 bolt conversion, Lunati springs, harden push rods, SLP oil pump, LS2 tensioner
- Kooks Custom Headers. X-pipe, mufflers, high flow cats, -Tuned by National Speed in Wilmington N. Carolina, HP Tuner 490rwhp and 483rwtq -Skip shift eliminator -RX Catch Can -CAI intake -Hurst Shifter, with custom Speed Dawg |
05-06-2012, 09:29 PM | #2 |
knows 2 facts about ducks
search
Here are the J-pipe lengths needed to cancel out drone at certain RPMs |
05-06-2012, 09:30 PM | #3 |
Do you have long-tube headers as well? I have the Kooks complete setup and there is noticeable drone from 1500-2000 RPM. Worst in 6th gear under moderate throttle. I added FatMat to the trunk floor and it helped. Now I either crack the windows an inch when driving around town or downshift to push the RPMs up over 2000 going up hills.
2012 - Present: 2011 CTS-V Sedan, A6, Airaid, Zmax TB and Tune by R.P.M. = 535 hp/503 lb-ft.
2009 - 2012: 2010 2SS RS IBM M6, MGW Shifter, BMR Trailing Arms/Tunnel Brace, Roto-Fab CAI, VMAX Ported TB, Kooks 6511-Complete (Headers, X-Pipe, Mufflers), dyno tuned by R.P.M. = 415 hp/412 lb-ft. "Not giving a f*^k is truly the greatest luxury, and no luxury car gives fewer f*^k's than a CTS-V." - Matt Hardigree |
05-06-2012, 09:57 PM | #4 | |
Drives: 2011 Camaro 2ssRS Ls3 Join Date: Aug 2010
In and out? I have j pipes and drone went away now the drone slowly came Back. Not as bad but still. I would like to get rid of it again --- I am here: http://tapatalk.com/map.php?1xwvrl
05-06-2012, 10:00 PM | #5 | |
05-06-2012, 10:33 PM | #6 |
Ya I need to figure out what lengths I need to tighten them too though.
--- I am here: http://tapatalk.com/map.php?kgbawc
05-09-2012, 06:49 PM | #7 |
Always Lookin
Thanks for the input, do you have pictures of you adjustable pipes? Where did you mount them? I am not a fan of j pipes that are mounted close to the mufflers. Thanks!
05-09-2012, 06:53 PM | #8 | |
Always Lookin
I imagine this is set up for your car and exhaust, as every car has a different exhaust system that gives out different frequencies.
05-09-2012, 06:55 PM | #9 |
Always Lookin
The adjustable pipes sounds like the way to go. The adjustable ones are called Solo J pipes?
05-09-2012, 07:16 PM | #10 | |
--- I am here: http://tapatalk.com/map.php?xe3afk
05-09-2012, 08:33 PM | #11 | |
Always Lookin
No pic was posted
05-10-2012, 06:00 AM | #12 |
Perhaps this will help with adjustment of Solo J-Pipes:
http://www.g8board.com/forums/showthread.php?t=28831 |
05-10-2012, 08:29 AM | #13 |
I actually just changed axle back mufflers due to drone...I researched and went through the whole idea of welding on a helmholtz or J tube from solo, the problem I encountered was that I was either going to have to accept a mild to stainless weld senario (which will corrode and rust) or find someone that tig welds thin metal stainless to stainless (which is hard to find). In the end I took off my SLP loudmouth II system which sounded awesome but droned badly when the engine was loaded from 1500-2000 RPMS. My wife didn't even want to ride in the car. I installed the Dynomax VT axleback system last night and even with Cam, LT Headers and 3" Catted mid pipes it now like near-stock inside with the windows up while riding with zero drone. It sounds good on the outside and you hear it whe you crack it the throttle open. I wish I would have taken video before and after while riding inside. It's an amazing difference...I'm just not sure I like not hearing the "good" growl anymore inside the cabin. I'll post a spereate thread on this in a few days with some video and talk more about the installation, fit and finish.
05-10-2012, 08:53 AM | #14 | |
Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
completely wrong.
Yeah, I'll get around to it...
