05-11-2012, 04:34 AM | #1 |
Drives: Camaro 2010 Ls3... 415rwhp Join Date: May 2012
spec stage2 clutch
hello every1 i have recently installed stage2 spec clutch from phstekperformance.com, in which they told me that it can be use with stock flywheel as it was mention in there website as well. now the problem is that when i installed in my car perfectly and during my driving in first gear my gear vibrates n then it stops when it goes to its normal speed and when i put in reverse it vibrates more.. is it because of new clutch or does it need to run for couple of KM to come to its position i am really confuse and the mechanic told me it will take time coz its new performance clutch. can any1 suggest me..
Actually i have 2010 ls3 camaro.. |
05-11-2012, 05:00 AM | #2 |
Drives: 11 IBM n White 2SS/RS M6 Join Date: May 2011
Vibration or is it chattering when youre engaging the clutch from a stop?
Sent from my DROID X2 using Tapatalk 2
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
05-11-2012, 05:26 AM | #3 |
Run that clutch for a few hundred miles and see how it is after, normally they don't vibrate, the stage II may chatter a little bit going from the stock organic disc to the kevlar until the disc has broken in a little...
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
Thread Tools | |
