Old 05-12-2012, 12:40 AM   #1
Chris@Livernois
Chris@Livernois's Avatar
Drives: 2010 Camaro
Livernois 9-Sec ZL1 Info and Video
See our website for our ZL1 specific packages. We can also build a package to fit your needs.
Specs:
Delivered by Rodger’s Chevrolet 4-27-12 (yes, we’ve only had it 2 weeks!)
2012 ZL1 Auto trans - Full weight with exception of wheels/tires
100% stock suspension
Stock trans w/ Livernois specific trans calibration
Stock catback
4,295 lbs. with driver
240 Miles
Mods:
Livernois Motorsports In-House CNC LSA Cylinder Heads
Livernois Motorsports Stage 2C High Lift Camshaft
Livernois Motorsports LSA Head Studs (Available soon)
Livernois Motorsports Exclusive Heat Exchanger (Available soon)
Livernois Motorsports Solid Supercharger Coupler
Livernois Motorsports Supercharger Pulley
Livernois Motorsports Exclusive Steel Idler Relocation Bracket w/ Metco Pulleys (Available soon)
Livernois Motorsports Spec’d Injectors
Livernois Motorsports Dual Fuel Pump Upgrade
Precision Industries Converter Built to Livernois Specs
Metco Oversize Crank Pulley Ring
Innovators West Oversize Balancer
Rotofab/Livernois Cold Air Intake (Available soon)
Stainless Works Longtube Headers & Connection Pipe
Hardened Pushrods
NGK TR6 Spark Plugs
160 Degree T-Stat
GM 90mm Throttle Body
Bogart 17” Wheels w/ Slicks & Skinnies
Livernois Motorsports Dyno Tune
Dyno Results Stock:
476 RWHP / 476 RWTQ
The best pass 100% stock with 110 miles on the odometer was 12.41 @ 115.9 mph. It was traction limited and the track was extremely busy, so I didn’t get a good feel for the car and how to launch it.
Dyno Results Modified:
707 RWHP / 680 RWTQ (Roughly 850 crank HP)
Note: Our tuner Dan Millen was at the track with me all day logging each pass and getting more and more aggressive after each pass, so I’m sure the power was quite a bit higher than what we saw on the dyno.
Just a little info on Dan, he is a multi-time 10.5 tire world champion who always sets the bar for the class. His car runs 3.7X @ 204 mph in the 1/8 mile!
I wouldn’t hesitate to daily drive the ZL1 with these mods (minus the wheels/tires).
I do plan on driving the car to Rodger’s Chevrolet for their show/open house tomorrow, then back to Milan on the stock wheels and Mickey Thompson ET Street Radials to see what it will run on 20’s.
The first pass off the trailer today, the car went 10.14 @ 138 MPH. Many of my launches were from just above idle and it was like a bracket car with several 10.0X-10.1X passes @ 138-141 MPH, and FINALLY on the last pass 9.87 @ 142 MPH!! Dan got pretty aggressive with the tune and told me to leave as hard as I could off the converter. We WERE going 9’s on this pass! I did the burnout, staged, then focused… not worrying about my reaction time (it was horrible as you can see), put it on the converter until it felt like it was going to roll forward and let it rip. I knew at the end of the track it was a good pass when I saw 145 mph on the heads up display.
We are also currently working with PSI Superchargers to improve the factory blower. Dan runs a PSI screw blower on his 3-Second 200+ MPH 1/8 mile race car.
Huge Thanks to:
GM for building an awesome car, Rodger’s Chevrolet, Milan Dragway for the great track, Innovators West, Metco, Mickey Thompson Tires, Precision Industries, Rotofab, Stainless Works… and the technicians at Livernois Motorsports!!!!!!
Vehicle Transport Services:
We realize that many of you are quite a distance from our Dearborn Heights, MI location and have interest in our services, but are not able to make the drive due to work and busy schedules.
We have a single vehicle enclosed trailer or a two vehicle enclosed trailer if there are two vehicles in close proximity to each other. With this service, you can trust that your car will make it to our location and back to you safely, and with much more power than it arrived with!
Cost of this service is very reasonable, but varies based on a distance and the availability of our trailer.
All cars are stored safely in doors before and after work is performed.
Please call 313-561-5500 or email info@livernoismotorsports.com for information and pricing.
Thank you
Regards,
Rick LeBlanc
Chris@Livernois is offline   Reply With Quote
Old 05-12-2012, 12:44 AM   #2
capnkirk52
Banned
Drives: 10 GT500, Raptor
Nice info and great times!
What do you think the limit is on the stock blower (far as boost, et, trap, and IAT's)?
How much boost were you running?
Auto trans looked solid, what would you expect from the manual trans?
Keep up the good work!
capnkirk52 is offline   Reply With Quote
Old 05-12-2012, 12:48 AM   #3
capnkirk52
Banned
Just watched vids again. The auto looks really nice. Did you put a stall on it? *edit* saw the mod list and that you had a converter built to your specs. What are your specs?
Old 05-12-2012, 01:09 AM   #4
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Now that's impressive! 700 rwhp and it runs 9's! Some guys around here have trouble running 10s with more power! LOL.
SUX2BU is offline   Reply With Quote
Old 05-12-2012, 01:30 AM   #5
Deki
Deki's Avatar
Drives: 2018 Mustang GT
Wow. That car makes it seem so effortless. Really hides the violence it possesses quite well. Good job.
2018 Mustang GT
Deki is offline   Reply With Quote
Old 05-12-2012, 01:33 AM   #6
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
It's pretty light too, about 40 lbs lighter than my car when I first ran it stock.
Old 05-12-2012, 01:57 AM   #7
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
WOW!!! This car is a beast!
armysig is offline   Reply With Quote
Old 05-12-2012, 02:00 AM   #8
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Subscribed.
Old 05-12-2012, 02:01 AM   #9
25thanniversary
25thanniversary's Avatar
Drives: 92 Camaro Convt RS,2011 Camaro RS
TEAM LLT
1992 Camaro Rs Convertible
2011 Camaro 1lt Rs
25thanniversary is offline   Reply With Quote
Old 05-12-2012, 05:55 AM   #10
zadjaliz
Drives: Not yet
Very Nice !!! Was this run with stock ported S/C or an Aftermarket S/C? race gas or pump gas? Nitrous?
zadjaliz is offline   Reply With Quote
Old 05-12-2012, 08:37 AM   #11
Bob Cosby
Drives: 2010 Vette
Great to see you guys post all of the details!
Serious question...any thoughts of loosening up the converter or launching off a trans-brake (assuming that's an option with the tranny)? Or are you intentionally launching a bit soft to ensure repeatability/durability?
That's hauling the mail in such a heavy car - neat!
Bob
Bob Cosby is offline   Reply With Quote
Old 05-12-2012, 08:43 AM   #12
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 05-12-2012, 11:15 AM   #13
navyblueSS
Drives: 2002 Camaro SS
Very impressive!
2015 1LE - CAI intake, TSP longtubes,
NPP, Futral Motorsports tuned, BMR 1"lowering springs, BMR trailing arms
navyblueSS is offline   Reply With Quote
Old 05-12-2012, 12:36 PM   #14
Monsterpost
Banned
Drives: 2010 Dodge Charger Police
What were you using for fuel and what weight reduction did you do?
Monsterpost is offline   Reply With Quote
