05-18-2012, 10:33 AM | #1 |
Is changing out lifters necessary with new cam?
A friend of mine who is a big-time 4th Gen enthusiast was telling me if/when I change out my cam that it is critically important to install new lifters at the same time. Of course, that goes along with installing new springs, push-rods, and rocker arms (or at least the Comp Cams LS tunnion upgrade). I see many people on these forums talking about swapping out there cams, and there is plenty of talk about push-rods and/or rocker arm upgrades to go along with the new cams. But I don't hardly see or hear anyone talking about changing out lifters. Is that not really necessary because our cars are so new and typically have low milage? Or is my buddy correct, and lifters should be changed out along with the cam swap? Just curious....please excuse my inexperience!!!
05-18-2012, 10:39 AM | #2 | |
Sent from my SCH-I510 using Tapatalk 2
top 10 reason why real men drive stick. 10. A manual transmission is the ultimate in control 9. You can use automotive jargon and not sound like a total tool 8. You can't spell "manual" without "man" 7. Manual transmissions prove you can do more than one thing at a time 6. You can't drift in an auto 5. You can't pull fancy moves in an automatic 4. You get better fuel economy with a stick 3. You’ll never look like a chump if you can drive stick 2. Manual transmission cars are faster 1. Women like a guy who is good with his hands. |
05-18-2012, 10:51 AM | #3 | |
by Odeon
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM Join Date: Nov 2011
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time." "The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy." 2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's) |
05-18-2012, 10:55 AM | #4 |
Prob not man
Shoot me a pm with ur number if i do.ill let u know..but i think my girl has plans Sent from my SCH-I510 using Tapatalk 2
05-18-2012, 11:02 AM | #5 |
Drives: 1964 Chevelle Join Date: Oct 2009
Lifters do not need to be changed, that is a very time consuming process.
The only things you need to change are Springs and Pushrods. We suggest changing to a double roller timing set for adjust-ability when degreeing a cam and for added extra strength. We also would suggest doing a trunion upgrade. Rockers are really not necessary and it has been our experience that a lot of the cheaper rockers sets will fail. Lifters are kind of the same ball park, the cheaper lifter has been known to cause issues. Unless you are building a car that is trying to utilize every last bit of power I would leave those pieces alone. Another good option at this time would be an ARP Crank bolt and a Underdrive Pulley. |
05-18-2012, 11:37 AM | #6 | |
Geek
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
05-18-2012, 12:36 PM | #7 |
Drives: 2017 1SS 1LE - Hyper Blue, P85DL Join Date: Jul 2011
My understanding is the only time you would want to upgrade lifters is if you were swapping heads, then you might as well do LS7 lifters for cheap insurance.
05-18-2012, 12:51 PM | #8 | |
Most double roller timing sets come with the shims needed to get the job done so its not like you need to find them. It really isn't to bad once you are in there. |
05-18-2012, 01:08 PM | #9 | |
Drives: Florida Speed & Power Join Date: Jan 2011
05-18-2012, 02:19 PM | #10 |
Drives: 2010 M6 2SS Join Date: Mar 2011
If you have an LS3, your stock lifters are the same as an LS7. There's no seperate PN anymore. Just regular lifters and DOD lifters in the DOD engines like the L99.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension |
05-18-2012, 02:57 PM | #11 |
Drives: 2010 Camaro L99 Join Date: Oct 2009
DOD Lifters ware removed for this VVT-3 Cam swap.
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os |
05-18-2012, 03:49 PM | #12 |
If it's an LS3 car with low mileage, I'd leave them alone...if you plan to take the heads off anyways, then I'd consider it depending on the mileage on the car...I think a lot of "sunk lifters" that I've heard about in person and online though...are not lifters making noise at all.
05-18-2012, 04:20 PM | #13 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Double roller chains are so Chevy 350's. You don't need them, I'd rather get a C5r single roller. I don't think most guys here make that kind of power to snap a timing chain. The advise should of been to remove the tensioner and adding an Ls2 dampner. Remember the harmonics are what really breaks those chains. Maybe a good pulley instead.
05-18-2012, 05:23 PM | #14 | |
Geek
The damper name gets used interchangably with tensioner (which i'm guilty of), and they mean different things. Resonance makes sense for breaking a chain. It even fits with the other logic i've seen. Basically... "the chain doesn't actually stretch, it just breaks". I'll find that post and requote it properly. All you really need is something in there to keep the chain from making a standing wave. I don't see how 2 chains is the most practical solution. A damper is the correct solution. Has to be
