Old 05-22-2012, 06:10 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
grind back. wow!
ok. so I have less than a 1000k on this new tranny GM put in again! ive lost count on how my iv had put and and rebuilt. its the 4th i believe.
So I was wondering with the dual mass fly wheel be causing this issue? I can tell the fly wheel is going bad cause you can head the noise it makes. clutch never slips and everything shifts fine but if you get near redline or above the shift is real notchy. im going to be easy on this untill i figure out the real issue with this damn notchy and grind shifting!
2010_camaro is offline   Reply With Quote
Old 05-22-2012, 06:27 PM   #2
Synner
Drives: cars
Most likely a hydraulics issue that isn't being addressed. The odds of having 4 straight clutches that are bad are astronomical.
Old 05-22-2012, 06:29 PM   #3
Synner
Drives: cars
And have they resurfaced the flywheel or checked it with each new clutch?
Old 05-23-2012, 11:41 AM   #4
2010_camaro
Idk if they even check the clutch. They only rebuild or replace the tranny. I think they blame my driving. I'm not hard on it. Even if I was the tranny should last longer!
Old 05-23-2012, 12:54 PM   #5
CyberPredator
50 Shades of Prey
Drives: TT/SS
Try the master Cylinder from Ideal G
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 05-23-2012, 02:11 PM   #6
brian ludwig
brian ludwig's Avatar
Drives: 2010 2lt
try putting in royal purple i have not had any problems after putting it in. i shift at 7 grand all the time now with no issue. maybe i am lucky but it cant hurt to try.
brian ludwig is offline   Reply With Quote
Old 05-23-2012, 04:51 PM   #7
CNC73
Drives: 2010 1ss m6 supercharged, 55 Chevy
I had royal purple in mine, made no difference. Works for some, not others I guess.
CNC73 is offline   Reply With Quote
Old 05-23-2012, 05:19 PM   #8
Synner
Drives: cars
Why do you continue to bring it to the same retarded dealer?
Why have you not elevated the issue?
Old 05-24-2012, 11:59 AM   #9
piticu667
Drives: 2010 Camaro
Check out the master cylinder thread ... I have the v6 too and the modified cylinder fixed my issue.
piticu667 is offline   Reply With Quote
Old 05-26-2012, 08:57 PM   #10
ponbigi
ponbigi's Avatar
Drives: 2011 CAMARO LS
Guys...the issue is high rev shift going into second gear. The 2nd gear simply cannot take it. Anything above 6200 rpm and grind... See if carbon fiber synchros are available and get the idealg fix. My tranny is getting fix and I plan on ordering the modified cylinder.
ponbigi is offline   Reply With Quote
