Old 06-13-2012, 06:16 PM   #1
BlackenedSS
BlackenedSS's Avatar
Drives: 2010 2SS Black on Black Camaro
19" wheels on SS?
Im sure this has been discussed, but what wheel company makes a set of 19" wheels that will fit a stock SS? I'm really wanting to go to an 18" but can't see it working out without changing calipers. I really like the TSW Nurembergrings, But I see them mostly in 20".
Also have been told that 19" tires are more expensive than 20". Needing new tires but I want to change the wheels out now.
BlackenedSS is offline   Reply With Quote
Old 06-13-2012, 06:32 PM   #2
black12lt
Drives: black 1lt 2012
Forum member sux2bu is running 18x10 in 4 corners on 285. I think they are forgestar f14. He too has an SS
black12lt is offline   Reply With Quote
Old 06-13-2012, 06:34 PM   #3
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Here is a member running 19x9.5 on each corner. They are Forgestar F14s.
Also, lots of guys are running 18" (Nurburgrings and Forgestars). You have to cut off the rollerskates if you have a 11/12 model. I just ordered a set of 18" for my car.
Unfortunately it takes a minimum of 2-3 months to get Forgestars.
Old 06-13-2012, 09:32 PM   #4
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Here is my thread on the first set of 18s I had.
http://www.camaro5.com/forums/showthread.php?t=151258
I lost 66 lbs of rotating weight when I switched to 18s. Car handles better, accelerates faster, stops quicker, it was by far the best mod I have ever done to my car. I even gained about 2 tenths and 2.426 mph in the 1/8 mile and about .364 seconds and 2.887 mph in the 1/4 mile. http://www.camaro5.com/forums/showthread.php?t=162390
Click this bar to view the small image.
SUX2BU is offline   Reply With Quote
Old 06-14-2012, 01:29 AM   #5
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
19" tires are no more expensive than 20's in my experience...here is my Camaro with 275/40-19's....Pic in signature shows 275/35-19's, about 1/2" lower...
So Cal Camaro is offline   Reply With Quote
Old 06-14-2012, 01:31 AM   #6
BlackenedSS
^This is what I'm going for^. Thanks I was looking at the F14, but wow they are proud of them! Not sure I can wait that long it's getting a little loose if you're not careful which doesn't bother me but the wife not so much! Guess I need to do some research now that I know it can be done.
Old 06-14-2012, 01:35 AM   #7
BlackenedSS
SUX2BU-love your setup. No trouble clearing in the back?
