06-18-2012, 04:44 PM | #1 |
Drives: 2011 2SS/RS cyber gray/black strip Join Date: Dec 2009
I wanna do it my self!!
So I plan on getting a VMax PTB,
I never installed a mod my self...and now I wanna do this one My self, I know it's really easy to do, but since its my first mod On my own, I was wondering of I can get some help from you guys Like, how to/video/pics/explain, Thanks! |
06-18-2012, 07:20 PM | #2 |
Drives: 2SS RS Join Date: Mar 2010
You need a screwdriver. Remove the old one, put the new on in it's place. It's really easy. Not sure I've seen pics or anything, but there are enough of us here that have done this we can get you straight if you run into issues.
Livernois 2C cam and tune, LS3 conversion, Roto-Fab intake, Kooks headers, DSS driveshaft and axles, BMR suspension parts, VMax ported throttle body, Whipple blower. (623hp).
06-18-2012, 07:39 PM | #3 |
Will I have to remove my intake? Or the MAS?
06-18-2012, 07:50 PM | #4 |
Remove, no. There is a rubber hose connecting your intake to your existing throttle body. Loosen, pull the old throttle body, disconnect the wire going to it, remove I think 4 bolts and pull the old one off. Put it back on, connect wire. Done. If you can change a tire you can do this.
06-18-2012, 09:09 PM | #5 |
Drives: 2009 ZR1 Join Date: May 2010
Pay attention to the torque specs on the throttle body. Dont over do it.
06-18-2012, 09:44 PM | #6 |
06-18-2012, 10:16 PM | #7 |
If the throttle body has any instructions it should say "torque to xx lbs" or something similar. All it means is how tight the bolts need to be. Auto zone or something similar can loan you a small torque wrench and show you how to use it, or you might want to buy your own if you plan on doing any more mods
B-Rex 2011 2SS/RS LS3 Hurst, LG, C.A.I., Flowmaster, Pfadt, Pedders, U.S. Gear/Axle Tech, LPW, SJM, Nitto, Nitrous Outlet, ZEX |
06-18-2012, 10:19 PM | #8 | |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
I believe the actual spec for TB bolts on the 5th gen is around 8-9ft lbs You will need a 10mm socket. Helps with a small extender as well for the lower bolts. Simply use a screw driver to loosen the hose band on the intake tube from the TB. Then unhook wiring harness from the TB. Remove the 4 bolts. Bolt down new TB. Hook up wiring harness then reattach the intake tube. Your done.
06-18-2012, 10:35 PM | #9 |
Drives: '10 2SS/RS, MKIII Supras Join Date: May 2010
Installing a ported TB is fairly straight forward. Remove intake tube, remove 4 10 mm bolts, remove OEM TB, then install ported TB.
06-18-2012, 10:37 PM | #10 |
is a tune required?
06-18-2012, 10:40 PM | #11 |
Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ |
06-18-2012, 10:52 PM | #12 |
Drives: Black 2011 2SS/RS Join Date: May 2011
06-19-2012, 01:06 AM | #13 |
Hmm, seems very simple, basically all I need to do it take 4 10mm
Bolts out...then put then back in, "beside the bolt TQ thing" But I'm sure I can do it, thanks for all the info guys, I can't wait to get it done, |
06-19-2012, 11:07 AM | #14 |
"Black Ace"
Drives: Supercharged 2010 SS, 2016 Golf R Join Date: Aug 2008
Yeah, definitely do NOT over-tighten them and break a bolt like I did the 2nd time around. Fortunately for me, there was enough threading sticking out to unthread it by hand with small pliers..
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq |
