Old 06-23-2012, 03:35 PM   #1
Indyblue98
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged
Chasing possible Vacuum Leak ? LTFT's +20 at Idle
Long Term Fuel Trims are reading +20 to +25 at idle (SCT TUNER )
Both Bank 1 and Bank 2 , But only at low rpm under 900
Driveabilty is good , and the LTFT's look good while driving.
Jannetty is providing tuning and wanted to see if there is a Vacuum leak .
Checked the easy stuff like Throttle Body and Catch Can.
Tried putting smoke around the edges of the intake .
Nothing obvious yet.
If there is a bad seal on one of the intake ports would that make both banks reading bad ?
Any ideas ?
Indyblue98 is offline   Reply With Quote
Old 06-23-2012, 08:46 PM   #2
Nessal
Drives: Exige, Miata, Ghia
I had this EXACT problem. Car drove fine but it read that LTFT were at 20%. Turned out that the intake manifold seals were leaking on cylinder #8 causing the car to run lean. The dealer replaced the complete manifold and since then everything has been good. My LTFT have been +-2% verified by my OBD scanner.
The dealer showed me the old plastic manifold and sure enough, the number 8 runner was melted and the gasket was all distorted. They said that it was most likely an assembly problem at the factory.
Nessal is offline   Reply With Quote
Old 06-23-2012, 11:51 PM   #3
greenmachinedriver
greenmachinedriver's Avatar
Drives: white 2010 ss and 2011 6.2 silvy
You can try spraying carb cleaner around any posible source and.watch your scanner to see if the short term fuel trim changes. You should see a momentary drop in stft if there is a leak.
2010 RS2SS, XS POWER HEADERS AND FULL EXHAUST, ROTOFAB COLD AIR AND ENGINE COVERS, MSD PLUG WIRES. PFADT DROP SPRINGS, SPORT SWAY BARS, TRAILING ARMS, TOE LINKS. HURST SHIFTER, BILLET PEDALS.
BLACKOUT TAIL PANEL, TINTED TAIL LIGHTS, MAIL SLOT BLACKOUT, WHITE BOWTIES
greenmachinedriver is offline   Reply With Quote
Old 06-24-2012, 12:01 AM   #4
BlackM6RS/SS
BlackM6RS/SS's Avatar
Drives: 2010 Black M6 RS/2SS
Do you have a fast intake?
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq
FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs
BlackM6RS/SS is offline   Reply With Quote
Old 06-24-2012, 01:00 AM   #5
GearBangr
Drives: 97Z,02TA
Its weird you mention that. I work at a full service shop, and last year I had a similar issue with a pickup. It was a 2010 with around 10k miles. The ses light was on, it was setting lean codes, and the ltft were in the 20s. I used our smoke machine and sure enough there was smoke coming from #8. When I pulled off the intake, 8 had the runner melted, enough to where light was visible. So maybe there was a bad batch of intakes that got out. I think I have pictures of it actually.
GearBangr is offline   Reply With Quote
Old 06-24-2012, 04:32 AM   #6
Nessal
They had their heads scratching for a day or two before smoking the manifold to isolate the problem.
Old 06-26-2012, 12:16 AM   #7
GearBangr
Drives: 97Z,02TA
Lol, that's usually my next step if I can't find anything visually or by sound.
Old 06-26-2012, 07:23 PM   #8
bad55nomad
Drives: 2010 Camaro 1SS A6 Inferno Orange
I had the same problem ending up being ported throttle body . Took it off problem solved
bad55nomad is offline   Reply With Quote
Old 06-26-2012, 08:45 PM   #9
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
A bad TB gasket seal can do it, or if the manifold was cracked when the TB was installed and now has a leak. You'll need to smoke the manifold to find the leak if you've already checked the hoses. Sometimes just smoking the edges won't reveal the problem.
2011 Camaro 1SS
Whipple Supercharged 1150/1100 @ 24psi - Removed blower and went Turbo
Huron Speed T6 1135/1070 @ 20psi so far. 15 more PSI loading...
Aries240SS is offline   Reply With Quote
Old 03-24-2021, 12:18 PM   #10
1LEsteiny
1LEsteiny's Avatar
Drives: 2015 1le
I might have to look into 3d printing each end and use regular brake ducts between
1LEsteiny is offline   Reply With Quote
