06-23-2012, 02:42 PM | #1 |
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged Join Date: Feb 2012
LTFT's +20 at Idle . Possible Causses ?
REPOST : From v8 Engine Bolt ons
Long Term Fuel Trims are reading +20 to +25 at idle (SCT TUNER ) Both Bank 1 and Bank 2 , But only at low rpm under 900 Driveabilty is good , and the LTFT's look good while driving. Jannetty is providing tuning and wanted to see if there is a Vacuum leak . Checked the easy stuff like Throttle Body and Catch Can. Tried putting smoke around the edges of the intake . Nothing obvious yet. If there is a bad seal on one of the intake ports would that make both banks reading bad ? Any ideas ? Whipple has been on for a few hundred miles , new mods are the Long tubes/High flow cats. No Data Logging till now, only 1900 miles now. Now has CEL . Mods: Whipple , Long Tubes W High Flow Cats , RotoFab . L99 Engine Last edited by Indyblue98; 06-23-2012 at 04:09 PM. Reason: CEL just came on |
06-23-2012, 03:17 PM | #2 | |
Drives: 2010 SS RS Join Date: Apr 2009
I just upgraded to Lion and need to reinstall hpt. Also, dl'd lastest 2.23beta. No exhaust leaks, cannot find vacuum leak. I do notice spikes in trim while driving and laying off throttle, but nothing like at idle with constant +20. I test tune has addressed the symptom, but haven't done enough logging since i upgraded failed hard drive and OS. 2010 LS3 w/kb 2.8 and LT. |
06-23-2012, 03:41 PM | #3 |
The Milano
Drives: 2017 Firefly ShipWorks Join Date: Jun 2010
More common cause this difficult to find would be.......... Catch can drain valve open causing a vacuum leak. It's easy to do.
Wouldn't anything above +\- 20 cause a CEL?
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter. |
06-23-2012, 03:47 PM | #4 |
Drives: Camaro 2SS/RS Ice Silver Join Date: Oct 2009
Check your MAF readings and wither you have strong MAF or not, also check if you have any exhaust leaks and check O2 sensors too. Did you installed the oem header gasket or not ?
06-23-2012, 03:58 PM | #5 |
2012 RS 2ss
Actually just went out to do some more checking.. CEL is on.
But has not been the last few times I drove for data logging. The car has a strong MAF . Basic's are when the throttle is almost closed . below 6% and rpms under 1000. When driving-acceleration the numbers are great .98-1.03 Checked the drain plug its ok. Reused the OEM Gaskets. Don't think there is a leak from those. Car is really quiet for having headers , still factory pipe past the cats. Last edited by Indyblue98; 06-23-2012 at 04:01 PM. Reason: more details |
06-23-2012, 05:38 PM | #6 |
positive ltft value means the mixture is lean and the ecu is adding fuel.
so lean means either the engine getting more air our getting less fuel. faulty o2 sensors, bad cats, major exhaust leaks, bad fuel injectors, bad fuel delivery all possible causes. did you upload a tune that correspond to your mods ? and don't worry, Ted@JRE is the man. He will fix it for you. |
06-23-2012, 05:50 PM | #7 | |
Have/had the same thing. Easy seal clamps on flanges, checked OE exhaust gasket area at LT flanges. Hi temp RTV around O2 and exhaust connections. Checked for vacuum leak. Good MAF sensor. Checked catch can system. Car runs good. Produces good power per setup. I know your pain... |
06-23-2012, 05:53 PM | #8 | |
2012 RS 2ss
And I know Ted hasn't given up , but since we both work day shift it leaves me with evenings to log data and the next day he anayizes and gives suggestions. My latest findings are : the Map sensor is a b#tch to get to , again, but at least it was properly installed a few days ago. More improtant I took the Catch Can out of the circuit and the LTFTs dropped to 1.08 -1.11 range. Thats just sitting in the garage. Need to find the proper way to route hoses without the catch can and do a road test / log data again . |
06-23-2012, 05:55 PM | #9 |
Drives: G8 GXP manual Join Date: Sep 2010
Need to get that CEL code first as it'll direct you to a likely source. Then again, the CEL could be because you've gone past the LTFT's limits before a code throws.
Mine at idle are 10 (can't recall if + or -).
2009 GXP, Manual with Sunroof
Zeta platform, LS3,TR6060 tranny ... ya, it's a 4-dr Camaro! Borla cat-back, H&R springs, & Sprintbooster & I love it! |
06-23-2012, 05:57 PM | #10 | |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
Air is getting in downstream, causing the O2 sensors to read high (lean), so it's adding fuel. So to IndyBlue: retighten everything. Had it happen when I installed my cats, easy fix. Padre |
06-23-2012, 05:57 PM | #11 | |
2012 RS 2ss
P0171 P0174 LFTT bank 1 and 2 So yeah the ECU is getting tired of the new high errors. |
Thread Tools | |
