06-24-2012, 06:16 PM | #1 |
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged Join Date: Feb 2012
SCT-LIVELINK Data Logs-Need Cheat Sheet
When data logging several items are logged in unfamilar units
Fuel pressure is over 400 Manifold boost some other crazy looking value Anyone have the values to convert for the common items ? |
06-26-2012, 12:06 AM | #2 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Your fuel pressure is defaulted to kpa units. When SCT works out all the bugs, you will be able to choose which unit you want, such as psi, Fahrenheit, etc. My sct with xxxxx.11 firmware displays my fuel pressure as 133 at idle. I need to multiply that by 3, as per the formula shown in list of pids. Then convert it to psi. http://www.csgnetwork.com/presskpapsicvt.html
or multiply kpa by .145 400*.145=58psi
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Thread Tools | |
