06-25-2012, 12:47 PM | #1 |
2012 Camaro ZL1 actual weight and weight bias
Just had my 2012 ZL1 on our corner weight scales in preparation for some future mods and just thought I would share the data.
This was a 2012 ZL1, manual trans, no sunroof without driver and almost empty tank of gas. Forgeline wheels are 8lbs lighter each than stock base rims. Stock Corner Weights: RF: 1074lbs LF: 1053lbs RR: 938lbs LR: 952lbs Total weight 4020lbs Diet perhaps? |
06-25-2012, 12:50 PM | #2 |
Quit being a pu$$y
Still lighter than my car stock. 4,130 lbs :(
06-25-2012, 01:02 PM | #3 |
Drives: 2010 Camaro IOM 1SS M6 Join Date: Aug 2010
Yes sir a diet would not hurt! Have any idea's as to what your thinking to loose a few?
06-25-2012, 01:20 PM | #4 | |
I also want to keep it streetable, so even though I will be replacing the seats with lighter ones they will not be all out race seats. Whatever we do, we will post actual weight savings here! /Erik |
06-25-2012, 02:18 PM | #5 |
Drives: VR ZL1 #259/Nissan 370Z NISMO Join Date: Aug 2008
Thanks!! Awaiting your tests...!
06-25-2012, 02:22 PM | #6 | |
50 Shades of Prey
Drives: TT/SS Join Date: Oct 2010
Futral Motorsports built and tuned
06-25-2012, 02:26 PM | #7 | |
LVL 50 Troll Stomper
Drives: 2010 Camaro Join Date: Feb 2008
06-25-2012, 02:28 PM | #8 |
Drives: Car Join Date: Jun 2010
06-25-2012, 02:28 PM | #9 |
Drives: 2010 Duramax; 2012 CTS-V Coupe Join Date: Apr 2012
Carbon fiber drive shaft, lighter flywheel and damper, cabron fiber trunk lid/spoiler/fenders, helium in the tires
06-25-2012, 02:30 PM | #10 | |
Well I am sure they did save weight on certain parts over the SS, but the overall package is still heavier. Figure in the much larger rear end, the whole blower assembly and the bigger brakes and there alone you have a couple hundred pounds. Although I am starting to think that someone hid some lead weights somewhere inside the body panels... /Erik |
06-25-2012, 07:37 PM | #11 |
Quit being a pu$$y
Yup. I weighed in at 4,330 lbs with me in it. Ginger is a big girl.
06-25-2012, 08:20 PM | #12 | |
Drives: C6 Z06 Join Date: Feb 2012
Are you gonna try to reduce? What do you attack? Backseat is worthless. Raceseats in the front would save some too. But whats that? 100lbs? Then what? Carbon fiber hood and trunk lid..... Aluminum lug nuts It has aluminum rotor hats right? Whats the radiator made out of? Mufflers with all that actuator stuff? You'd probably be doing real good if you could find 300lbs. Last edited by speedmon; 06-25-2012 at 08:37 PM. |
