07-01-2012, 12:05 AM | #1 |
Drives: 2010 Black M6 RS/2SS Join Date: Oct 2009
Best Bluetooth scanner for iPhone
What's the best obdii blue tooth adapter and what app is best for iOS. I searched but the other thread is mostly Droid.
What do I need to monitor and see logs and paraneters.
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs |
07-02-2012, 09:32 PM | #2 |
Drives: 2010 2SS Grey/silver stripes Join Date: Feb 2010
Curious about this myself...
2010 2SS LS3/ Custom painted gunmetal grey with "ghost" silver stripes / Roto-Fab CAI / Skip shift eleminator / Barton short throw shifter / 20% tint / muffler delete / ******** stealth enclosure with JL Audio 8W7 powered by a JL Audio J2 500.1
07-03-2012, 01:15 AM | #3 |
Innovate OT-2 & Log Works. Not Bluetooth though, but WiFi. It's got all the stuff you need, including data logging capabilities and the option to connect a LC-1 AFR controller giving accurate AFR readings. Nice piece
I'll be installing it today
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73) CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials |
07-07-2012, 09:49 PM | #4 |
I got the Kiwi PLX WiFi obd adapter going to use DashCommand app.... Didn't see the other mentioned here till now. My main concern is Knock Retard.... I dont know if it will show it but other things is cool none the less.
ADM H/C/I M6 480rwhp 435rwtq FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs Last edited by BlackM6RS/SS; 07-08-2012 at 09:26 AM. Reason: Spelling |
07-07-2012, 10:03 PM | #5 | |
Sorry, I kouldn't help myself.
07-08-2012, 09:26 AM | #6 |
Good one typo fixed
Thread Tools | |
