07-07-2012, 05:25 PM | #1 |
Drives: 2017 SS 1LE Join Date: Jun 2011
Just installed some headers today and have a ?
Ok.... I spend like 7ish hours installed headers in this heat today...
I installed some ARH long tube headers with high flow cats. I also already had on a MRT v2 and a BBK air intake. so.... I start up the car and everything sounds "fine" meaning louder, which is what i expected and all. But when I go for a spin down the road, it sounds higher pitched than before and very raspy up to about 4800rpm, then it sounds down right mean. Is this normal? also... I havent hooked up the o2 sensors yet, cause im waiting on extension cables, and also I'm going to get a tune. Now my question is, will hooking back up the o2 sensors and getting a tune have any impact on the raspyness? |
07-07-2012, 06:05 PM | #2 | |
Drives: SRT Yugo GT Super Sport with Manual Join Date: Mar 2012
07-07-2012, 06:08 PM | #3 | |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
07-07-2012, 06:22 PM | #4 |
Let's go Rangers!
This!
07-07-2012, 09:08 PM | #5 |
Do I need to have it welded? Or can it be put on using band clamps?
07-07-2012, 09:52 PM | #6 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
07-07-2012, 10:01 PM | #8 |
Banned
Drives: 2011 White Camaro RS Join Date: Mar 2012
get the magnaflow true x pipe or a h pipe to clear the raspy its a echo from front to back but like i said n that should eliminate that o2 sensors can cause exhuast leak atleast plug em in but use a zip tie to tie around whatever u can untill u get the extensions
07-07-2012, 10:21 PM | #9 |
Thanks for all the help guys.
Whats the diff between a X pipe and a H pipe? and yes, I have the O2 sensors installed, but just have the wires zip tied up. |
07-07-2012, 10:26 PM | #10 | |
Booooosted.
But do the X-pipe. You'll be glad you did. Get rid of that shitty resonator. As far as the X-pipe vs H-pipe it's really just sound. Just to the X pipe. |
07-07-2012, 10:28 PM | #11 |
Booooosted.
Reason you will not find one prefabbed is because once the resonator is cut out the typical fabbed x-pipe wont' be long enough.
07-07-2012, 10:28 PM | #12 | |
So I have to remove a "resonator"?, sorry in advance haha. I'm still learning |
07-07-2012, 10:28 PM | #13 | |
Booooosted.
Give me a second, I'll put up an illustration.' |
07-07-2012, 10:30 PM | #14 |
haha ok, I might just pay a shop to install in. After sweating out in the heat for 8 hours today fighting with these headers. How much is a fair price for someone to install it?
