Old 07-09-2012, 03:20 AM   #1
aj.crognale
aj.crognale's Avatar
Drives: '12 Summit White 2LS
My new trim
This is what I've been doing with a few of my days off from work. Personally I think its night and day verses the bland textured gray plastic that comes with the LS trims. It's all a textured white carbon fiber now and I even did behind the door handle as a subtle "thats awesome" kinda thing. So far everybody that sees it wants it.
The front and rear bowties are done as well. Not a new idea, but done right it looks great!
Let me know what you all think.
aj.crognale is offline   Reply With Quote
Old 07-09-2012, 03:36 AM   #2
DPerry
DPerry's Avatar
Drives: 2010 Black LT
Looks awesome! I'm actually doing this next week with blue CF. Are there any tips or recommendations you can share!?
http://www.camaro5.com/forums/showthread.php?t=387407
DPerry is offline   Reply With Quote
Old 07-09-2012, 04:03 AM   #3
aj.crognale
I took all the parts and sanded them down with a low number grit sandpaper and then went to a higher grit (150 If I recall) just to smooth it out a little for the vinyl to go on smooth, but rough enough for the adhesive to have something to grab onto.
When you're wrapping the parts make sure to use a heat gun (preferably) or a hair dryer to get the vinyl in the crevasses and corners. Take your time and do it right so it doesn't come back and bubble up on you. HEAT IS YOUR FRIEND.
When I was done I left the pieces off and kept them in the passenger seat for a day so the sun could do its work and to check if I had any bubbles I couldn't see. One of the sides bubbled up and I just reheated it and stretched the vinyl back out to fix it. The other side was fine, but it was a good test and I avoided taking the door panels off and on for a second time.
It maybe a little time consuming, but its worth it to do it right. The sanding was probably the longest part of the entire thing.
Old 07-09-2012, 04:35 AM   #4
DPerry
DPerry's Avatar
I don't have textured panels so that saves me time from all the sanding But thanks for the info. I hope mine turns out as good as yours lol
Old 07-17-2012, 07:40 PM   #5
mdelat2LT
mdelat2LT's Avatar
Drives: 2012 Black 2LT RS
Looks great man! How much material and from where did you purchase?
mdelat2LT is offline   Reply With Quote
Old 07-17-2012, 07:53 PM   #6
Cliffjumper
Cliffjumper's Avatar
Drives: 2013 2LT RS Black
I had done white leather in my door handle cup I get so many complements on it. It's surprising all the big expensive things you do and it's the cheap little things tht get noticed lol
Cliffjumper is offline   Reply With Quote
Old 07-17-2012, 07:54 PM   #7
Cliffjumper
My armrests are also white leather
Old 07-18-2012, 01:52 AM   #8
aj.crognale
I'm starting a little decal business so I got mine from a local vinyl supplier, but just go on ebay and order at least 24" x 36". That's if you can do it perfect, and I messed up the very first time so I had to reorder and at a larger size.
