07-11-2012, 12:16 PM | #1 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
Fog Wiring....
Okay so I asked a question on how to wire fogs to have them only on at night and received a lot of helpful suggestions and got them all wired up. They look amazing! So thanks a lot guys.
Here's my question, my good friend and neighbor also owns an ls. He liked how mine looked and asked if I could help him install his that he just got. He wants his on all the time that the turns the car on. How would I wire that? I was thinking wiring from the battery post but then they wouldn't turn off when the car is off. So does anyone know how to do it? |
07-11-2012, 12:20 PM | #2 |
Drives: 2010 Camaro Join Date: Dec 2010
You would have to tap into a source that is on with the ignition. I can't think of a source off the top of my head. Good luck
07-11-2012, 12:27 PM | #3 |
Drives: 2015 Camaro 1SS Join Date: Dec 2011
I believe the "cig lighter" is an ignition on power source.
Or you could do as you mentioned and tap directly into a 12V source, and just wire up a simple switch in the cabin. |
07-11-2012, 12:49 PM | #4 |
I would do the cig but that fuse is in the cabin and would really like something in the engine bay. He doesn't want to run a switch. So that's out :(
07-11-2012, 07:08 PM | #5 |
Fuse #15 under the hood is only on when the ignition is on.
07-11-2012, 08:09 PM | #6 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
Talk to Ofer (2SSRS), he does a harness for that exact setup. plugs into factory weiring, relay and fuse protected. The best way to do it
http://www.gen5diy.com/ |
