![]() Drives: 2012 2LS Join Date: Jun 2012
Turn signal
OK see if i can describe what i need.
I bought a LED scanner for behind the grill of my 2012 2LS It has turn signal abilities, but our turn signals glow constant. i need a trigger with a always off mode, AKA only 12 volts when signals are one not 12 constant like ours confused yet>..?
The turn signals don't glow all the time, your park light does. There're a separate wire for your turn signal and a separate wire for your park light. There is a thread on here somewhere on installing a set of side mirror turn signals. Plenty of pics, check it out and it will tell you which wires you are needing to tap into. Hope that helps
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
Yes, budmc is right. Your parking lamp is the one always on which is a separate wire from the actual turn signal.
Heres that link to the Side Mirror Turn Signals....
http://www.camaro5.com/forums/showthread.php?t=113157 ...if it helps any at all |
