![]() Drives: 2013 2LT RS Black Join Date: Feb 2012
How hard to install gm high wing spoiler
Getting one soon and wanted to install my self would it be worth it or just let the dealer do it for extra 150$
Oh and I have a clean trunk btw no spoiler
If it was me and holes weren't drilled I would let the dealer do it. If they mess it up it's on them, if you mess it up you will be pissed off and it will cost more to fix
My Build Thread
http://camaro5.com/forums/showthread...=1#post5036900 Maureen@Rodgers Chevrolet...The best prices and customer service period!!(734)676-9600 Gen5Diy.com.....http://www.gen5diy.com/ Wretched Motorsports..www.wretchedms.com/ Pedders USA...http://www.peddersusa.com/ |
![]() ![]() ![]() ![]() ![]() Drives: Black 2011 Camaro LS Join Date: Feb 2011
Contact becky@rogers. She can get you a template that you lay on the trunk lid to mark where you drill. It is the same template they use at the dealer service department. Also, lay down several layers of painters tape when you drill. It will help avoid scratching the lid should your bit slip and it will help prevent the metal shavings from scratching as well.
Edit: Here is a simple "how to". http://www.camaro5.com/forums/showthread.php?t=204678 It looks like you get a template in the box, BUT if you don't, contact becky. She can hook you up!
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob SS Fascia, Factory RS HIDs, Plasma P13W fog lights Non-RS to RS and fog light harness by Gen5DIY LED Interior, Trunk, and Licence Plate lights in white ZL1 Spoiler with Gen5DIY harness Factory NPP cat back Blacked out tail light bezels Factory 20 inch wheels wrapped in Nitto Motivos Lowered 1.25inch on Eibach Pro springs Last edited by My Caroline; 07-17-2012 at 12:10 AM. |
Thanks randell
#6 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
Easy if you have a naked hood....
Good luck! Ivan |
#7 |
Thanks I'll need it. Even with a template it is scary drilling a hole in your baby
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LS V6 Join Date: Jul 2010
its just 4 holes. as long as u have a template you cant go wrong. drilling was the easy part. finding that damn 3rd brake light plug behind the seat is a b*%*#(
but its not bad at all
C-LO or Sonic
"Without Struggle there is no progress" I am your best nightmare! |
#9 |
Do you possibly have a pic of the harness there and the connection
#10 |
C-LO or Sonic
#11 |
I like teeth.
Drives: #198 Join Date: Oct 2009
I thought overall the entire thing sucked. It definitely is a two person job, no working around that.
Every part of it for me was frustrating and I wouldn't want to do another. But I did it because I don't want to pay some outrageous install charge. Took me about 4 hours to do with a friend, but it can be done faster if you know what you're doing. The harness part took me about 45 minutes because I was dumb and kept trying to pull it off with my hand. Use a super small flat blade and you can unclip the harness in two senconds.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
