Old 07-26-2012, 02:58 AM   #1
v6
v6's Avatar
Drives: 2012 45th 2LT RS
Camaro letters on trunk panel?
wondering what the best way to get a perfect spacing for this is. im using the same letters that are on the front fender and putting them on the trunk where the chevy emblem is. how do i space them out perfectly? measuring tape is an obvious answer but... anything better?
v6 is offline   Reply With Quote
Old 07-26-2012, 03:30 AM   #2
Cliffjumper
Cliffjumper's Avatar
Drives: 2013 2LT RS Black
If you want perfect you are going to have to do math. I use viny and a ruler. Or in your case maybe a yard stick stick it to the vinyl and you are going to stick your letter face down and backwards Measure out your trunk lid and figure how fare you want the first and last letter apart from the edge and mark it with tape measure the distance between and then divide by 7 (the amount of letters in Camaro) then measure each letter add them up and minus from total that will give you the space that needs to be between each letter then start sticking and spacing cut the vinyl down to a manageable size and that will be your set up. The just put it on the Camaro straight that one you have to figure out. Good luck hope this helps
C.an A.lways M.od A.nd R.ace O.ften
Cliffjumper is offline   Reply With Quote
