08-07-2012, 08:49 PM | #1 |
NSM
Drives: 2012 AGM 2SS/RS Join Date: Feb 2012
STP Son of a Gun Tire Foam
Hey guys,
I wasn't sure if I should have posted this in the Tires forum or here, but since it has to do with cleaning, I posted it here. Have any of you guys used this product? Is it good? Also, if the foam drips on to the rim, will it hurt the rim? Thank you.
Stay hungry, stay foolish.
08-07-2012, 09:13 PM | #2 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
They still make that stuff? There are a lot better products like gels that last longer. It won't hurt your wheels, but I would spray it on something else instead of applying it directly to the tire since it will get on the rim.
08-07-2012, 09:53 PM | #3 |
Never heard of it. Don't care for sprays generally.
[B]
08-08-2012, 06:53 AM | #4 |
Drives: 2014 Ford Focus ST Join Date: Jun 2009
If you in a tight spot then it's OK to use, but you valve your Camaro then you should also value your tires and rims. Go to the Autopia Car Care Store and get the finest products for your ride.
