Old 08-16-2012, 05:34 PM   #1
wyd_trkr
wyd_trkr's Avatar
Drives: 2016 Camaro 2LT/RS A8
Question "HOW TO" install this www.gen5diy.com DRL Replacement Harness
Hey guy's! Like the title states, do any of you have the Installation Instructions on How To install this new gen5diy DRL Harness?
Also, do you really have to change the DRL bulbs to use this new harness or no? Thanks for any and all replies, as I would like to install this DRL Harness tonight if it does not interfere with my present DRL Bulbs!
Regards, wyd_trkr
Bose Premium System
My Link Navigation
Onstar & Bluetooth Built-In
K&N Panel Filter
Lumar/Pro WindowTint
Mailto: wyd_trkr@bellsouth.net
wyd_trkr is offline   Reply With Quote
Old 08-16-2012, 06:15 PM   #2
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Is this harness so you can run the DRLs at the same time as your headlights?
If yes, then remove the torx screws towards the front of the front tire wheel well. Pull open wheel well cover so you can see DRL housing. Disconnect plug from DRL, connect factory connector you just disconnected to the DRL harness. Connect other side of DRL harness to DRL. Put back wheel well cover and screws.
Old 08-16-2012, 06:43 PM   #3
wyd_trkr
wyd_trkr's Avatar
Do those instructions pertain to the Inner Fender Panel removal on the Driver or Passenger side to replace this harness? Also do you have to replace the DRL Bulbs for this to work without burning out the Bulbs? Thanks for your response as I would like to install this DRL Harness tonight?
Old 08-16-2012, 08:06 PM   #4
camaro2lt
camaro2lt's Avatar
you take out the 3 torx screws in each fender well.......and the harness will go on the pass side in between the fascia harness and the harness coming from the car....no you do not have to change the bulbs
Old 08-16-2012, 08:21 PM   #5
wyd_trkr
wyd_trkr's Avatar
Question
From what you are stating I only have to take the 3 Torx Head Screws out of the Inner Fender Panel on the Right Passenger Side correct?
Then I unplug the DRL Harness and plug the new Pigtail into the DRL and plug the factory harness back into the other end of the New Pigtail, correct?
Regards, wyd_trkr
Bose Premium System
My Link Navigation
K&N Panel Filter
Old 08-16-2012, 08:39 PM   #6
HaubSS
HaubSS's Avatar
Drives: '11 IBM 2SS/RS LS3/M6
Yup you got it. Should take about 15 mins.
2011 IBM 2SS/RS - LS3/M6 - Grey Interior
Full bolt-ons + TSP 229/236, 112 LSA
Tuned by STARKWEATHER PERFORMANCE
BMR Stage 3 suspension
MRR 288 - 20x10(+35), 20x11(+43)
HaubSS is offline   Reply With Quote
Old 08-16-2012, 08:41 PM   #7
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
Originally Posted by wyd_trkr View Post
From what you are stating I only have to take the 3 Torx Head Screws out of the Inner Fende Panel on the Right Passenger Side then correct, Not the Driver & Passenger Sides?
The Passenger Side is where the harness factory pigtail is located and just unplug it and replace it with the new one, correct?
Correct
Caddy
Caddyroger is offline   Reply With Quote
Old 08-16-2012, 08:42 PM   #8
camaro2lt
camaro2lt's Avatar
soory yea only take the pass side!
Old 08-16-2012, 08:49 PM   #9
wyd_trkr
wyd_trkr's Avatar
Thanks guys! I really do appreciate the help!
Regards, wyd_trkr
Bose Premium System
My Link Navigation
K&N Panel Filter
Old 08-16-2012, 08:53 PM   #10
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
If I remember correctly, the size of the torx screws is T20.
It really is about a 5 min job. It takes longer to get in the car, turn it on, turn the steering wheel to get to the screws and then when your finished turn the steering wheel back to it's original position then it does to actually do the job.
Old 08-16-2012, 09:05 PM   #11
camaro2lt
camaro2lt's Avatar
^^^^^yes they are t20
Old 08-16-2012, 09:17 PM   #12
wyd_trkr
wyd_trkr's Avatar
Okay guys, it took about 15 minutes for me to go out in the garage and install the New gen5diy Pigtail and it works are advertised. Now I can see why others did change the DRL Bulbs, as they look Milky and yellowish compared to the HID'S. Guess I will order the Bulbs tomorrow! Where and what new DRL Bulbs would you guys recommend I buy for me car to be close enough match for the Headlights? ...
Regards, wyd_trkr
Bose Premium System
My Link Navigation
K&N Panel Filter
Old 08-16-2012, 09:23 PM   #13
camaro2lt
camaro2lt's Avatar
get p13 plasma bulbs!
Old 08-16-2012, 09:41 PM   #14
wyd_trkr
wyd_trkr's Avatar
Question
Are the Plasma Bulbs better than the LED Bulbs? Also, I am looking at longevity as well in either or type Bulb?
Who should I buy them from?
Regards, wyd_trkr
Bose Premium System
My Link Navigation
K&N Panel Filter
