![]() Drives: 2011 Camaro 2SS/RS Vert Join Date: Jul 2011
Backup Camera Help!!!
when i shift into reverse nothing happens the only thing i see is a light in the morror starts flashing? What does this mean? Did I do something wrong, its almost like the camera doesnt have power....Help!
Quit being a pu$$y
What harness and mirror did you use?
ofer and the one ofer pointed me to on ebay from cooper_z71 gentex567 or something like that
Quit being a pu$$y
You getting power and ground?
huh? i have the power hooked up and the camera is grounded
#6 |
would it help if I connected the camera straight up to the reverse lights in the harness connected to the tail lights? The display in the mirror never comes on so maybe the mirror display isnt getting power
#7 |
Quit being a pu$$y
Sounds like your problem is in the mirror. If you have a small portable TV hook up the Camera's video RCA to it to make sure you are getting video.
#8 |
okay i will try thank you!!
#9 |
![]() Drives: Yes Join Date: Nov 2009
#10 |
okay is the little tv in the mirror supposed to come on no mateer if a camera or anything is hooked to it? because I plugged a little game thing up to it and it didnt work either im pretty sure its not the camera.
#11 |
Yes I purchased it.....I didn't have the option to get a camera on an '11
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 1LE Join Date: Jul 2011
My LCD mirror has a power button just for the display Sometimes it can be turned off when adjusting the mirror.
#13 | |
I turned in a '10 coupe to get the factory camera (and the soft top). I'd have had fewer problems if I had gone your route with the '10 and an add-on camera, rather than the Pandora's Box Convertible. ![]() tramtwo's suggestion sounds good. Maybe it's just turned off. |
#14 |
Okay I got a new camera and hooked it up this is what happens. Attachment 418246
I can see out of it, but it is very staticy and the colors are messed up....help! Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
