Old 08-27-2012, 06:08 PM   #1
rayray11
rayray11's Avatar
Drives: 2011 Camaro SS Inferno Orange
FS: RX Performance Oil Catch Can, Inferno Orange
SOLD! THANKS Brand New Never taken out of the bubble wrap. Painted Inferno Orange.
2010-2012 Camaro SS V8 - RX Performance - PCV Catch Can
N
The RX Performance Single Valve Catch Can is designed for Naturally Aspirated or Roots/Screw Supercharged 5th Gen Camaros. This kit includes a black bracket and hose for installation.
The RX Catch Can features a perforated dispersion tube running down the center from the inlet that disperses the gasses to contact the most possible cooling/condensing surface. It's optimal size allows for a slow flow to drop out of suspension where it travels to an internal disc baffle system giving it one more surface to contact and cool forcing it to contact the outer cooling surface evenly before exiting through and integrated poly check valve to prevent any reversion.
The RX Catch Can has an easy drain valve on the bottom and a remote 1' long drain hose to zip tie in place so you can simply put a drain pan under the car to catch it. This means no mess, no dis-assembly, and no internal cleaning needed ever.
Another great feature is that this is the ONLY can on the market with an integrated PCV/check valve to ensure the proper flow/metering that the LSx V8's require.
$120 Shipped anywhere in the 48 States.
PM me if you want more picture or any questions.
rayray11 is offline   Reply With Quote
Old 08-28-2012, 10:49 AM   #2
rayray11
rayray11's Avatar
Sold! Thanks!
