Old 08-29-2012, 09:54 PM   #1
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Retrofitted NPP exhaust on my 2010
Thanks to a member here, I was able to get a new take off NPP catback and rear diffuser. I also purchased NPP in a box from GM Parts House to control the butterflies.
It's a straight forward install. Remove the stock rear diffuser, remove the catback (Magnaflow Street in my case), install the NPP catback, install new diffuser, and hook up the NPP controller.
Video of first start up before I hooked up the controller.
http://s28.photobucket.com/albums/c2...AD6F90E008.mp4
New diffuser on.
Controller.
Hook up for vacuum hose.
Kinda looks like a mess in this pic. Since I have a BAP for my Whipple, I just tapped the vacuum hose going to it. I figure there was no reason to run a whole new hose all the way to the engine. So far, no issues with the butterflies opening due to boost. If I do have an issue, I figure I can add a check valve at any time.
In order to keep the least amount of vacuum hose possible outside the car, I fed the hoses through each side. Here's the place I used on the driver side. Look all the way back. It puts the vacuum hose right at the connection point on the muffler.
I wanted to use the same place on the passenger side, but I already had BAP wires and hose there and there just wasn't enough room for another hose. You can see where I routed it in this pic. It's not ideal since something could be put on the vacuum line in the trunk. However, it's very close the the rear of the trunk and it would have to be something extremely heavy to affect it.
I grounded the controller using the bolt that grounds the main battery wire. Then I ran the power wire to the fuse box in the rear passenger side. I already had the hole drilled from previously wiring up the BAP. This time I tapped the fuse for the stereo amp.
And here's a video testing the controller. I also programmed buttons on my Homelink to control the butterflies so I don't have to use the remotes that came with the kit.
http://s28.photobucket.com/albums/c2...E385149A18.mp4
I really like the sound of the exhaust at idle and low RPM. However, with the butterflies open, WOT is a little raspy. If you like Corsa, you will like this. It's not deafening like the Corsa, but sounds similar to me. Keep in mind, I have Kooks longtubes and cats. Closing the butterflies really does cut down on the drone and WOT is much quieter. I also really like the look of the quad tips.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 08-30-2012, 08:06 AM   #2
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
Lucky punk. I'm also waiting on my donor car to switch his catback to do this mod. I already have the diffuser. I don't think I'll be installing the NPP. I think I will leave the butterflies open all the time.
2018 MBM ZL1 6spd Coupe https://youtu.be/fM9silIzdcI
02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 08-30-2012, 12:56 PM   #3
JWoj3540
JWoj3540's Avatar
Drives: 2012 2SS/RS M6
nice write-up. what part number was your magnaflow catback?
JWoj3540 is offline   Reply With Quote
Old 08-30-2012, 01:52 PM   #4
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Cool, I'll be installing mine this weekend
Old 08-30-2012, 02:43 PM   #5
yotaman96
yotaman96's Avatar
16579
2002 Trans Am
Old 08-31-2012, 10:44 AM   #6
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Looks good!
I don't know why, but I thought I've seen others here take off the entire rear bumper to replace the diffuser...Is it just as simple as pulling off the diffuser?
Old 08-31-2012, 12:27 PM   #7
yotaman96
yotaman96's Avatar
Originally Posted by Iwantone2 View Post
Looks good!
I believe it was six bolts and a bunch of tabs. The tabs can easily break. I wasn't worried about it since my diffuser had a bad spot already. I broke two tabs taking it off. I'm sure it would still work fine if I decided to put it back on.
2002 Trans Am
Old 10-19-2012, 01:13 PM   #8
Cdubbcamaro
Drives: Zl1
I have a zl1 dual mode exhaust with 2200 mile on it never seen rain for sale for 650.00 pm me if interested
Cdubbcamaro is offline   Reply With Quote
