09-03-2012, 05:38 PM | #1 |
ZL1 - The Legend Returns!
Drives: 2013 ZL1 Camaro Join Date: Jul 2012
HUD Shift Light Working or not working?
In screen 4 I believe on the HUD you have the shift light indicator that is supposed to come on after 3200 rpm. Well it seems to be working in first gear but not other gears. I havnt wound it out ( still in break in) but shouldn't it come on after 3200 in every gear?
09-03-2012, 06:54 PM | #2 |
Drives: ZL1, Genesis, Grand Cherokee Join Date: Feb 2012
Yes
09-03-2012, 08:10 PM | #3 |
Catch me if you can
Works on mine...
09-03-2012, 08:39 PM | #4 |
Mine comes on only in 1st gear. 2nd-4 up to 4k rpm does not turn on the shift light. Anyone have this issue?
09-03-2012, 09:08 PM | #5 |
Btw I have a 6 speed manual. Havnt seen the gear indicator either. ???
09-03-2012, 09:13 PM | #6 |
'12 ZL1 #742
Drives: his wife crazy Join Date: Nov 2011
I think the higher the gear, the higher the rpms before the lights come in since it takes longer to reach the shift point. Just speculating from what I've seen so far.
09-03-2012, 09:23 PM | #7 |
Drives: 2017 2SS 50th Anv, 1972 RS Join Date: Mar 2009
I havnt see the shift light at all. But I usually shift before 3200 rpm. On another note, the car just started making me doing skip shift, I didnt know it was on the ZL1.
09-04-2012, 01:07 PM | #8 | |
Drives: GM Vehicles Join Date: Jun 2010
ZL1 vehicles equipped with a Head-Up Display (HUD) also have shift timing lights across the top of the display. As you approach a shift point, the rows of lights grow closer together. The transmission should be shifted before the lights come together in the middle of the display. If the lights begin flashing, you have exceeded the shift point. Shift immediately. If you feel like you may be experiencing an issue, it would be best to get a proper diagnosis at a dealership. Brandon Chevrolet Customer Service
09-04-2012, 01:09 PM | #9 |
'12 ZL1 #742
tested it out this morning... the lights don't come on in 2nd until you get close to 5k rpm
09-04-2012, 04:38 PM | #10 |
Awesome! Thanks. That's the answer I was hoping for. I've been good during break in so i was hoping it was an RPM thing. They advertise 3200RPM and above. I assumed it was different in each gear. This makes sense. Thanks again.
Thread Tools | |
