09-12-2012, 09:16 AM | #1 |
The Machinist
Drives: 2012 2SS/RS LS3 IBM silver rally Join Date: May 2012
Cylinder heads?
What brand of heads make the most power on these engines? Mast? AI? I am looking to get a set and need some input. Thanks.
American Racing Headers w/high-flow cats and x-pipe, Flowmaster American Thunder Axle-back mufflers, VMAX ported throttle body, CAI intake, ADM race scoop, RX Catch Can, PEDDERS Street Z package-ZL1 sways-XA Coilovers, PFADT trailing arms-toe rods, RPM 3:91 gears, RPM Stage V Trans, ADM diff bushings, tune by ADM, and still bustin' knuckles!
09-12-2012, 10:18 AM | #2 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
Mast bought out PI which (IMO) used to be the best damn head you could put on a LS3.
I'd challenge that Mast is now holding that down and I know that there is some stiff comp out there with the WC Heads, AI heads, and 510Racing being some of our favorites as well. Good luck in your quest! Ivan |
09-12-2012, 10:53 AM | #3 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
Mast black label...to bad they cost as much as a short block!!!:(
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
09-12-2012, 11:51 AM | #4 |
The Machinist
What kind of HP gains will I get from the black label?
09-12-2012, 12:00 PM | #5 |
Drives: 2012 Camaro 2SS/RS 45th Anniv Edt Join Date: Aug 2012
I would say All Pro hands down. They been making great heads on LS blocks for a long time. All the fast guys/gals are using them.
09-12-2012, 03:02 PM | #6 |
Drives: 2011 SSm6 Join Date: Oct 2011
Has anyone actually ever seen a decent engine dyno test, showing aftermarket or ported heads against the stock heads, on a stock cubic inch LS3? I havent.
09-12-2012, 04:21 PM | #7 |
I have.
09-12-2012, 06:30 PM | #8 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
GMHTP did an article that tested every head out there against the stock heads and the MAST showed best gains and the very reason I went with the MAST Black Label heads.
09-13-2012, 07:55 AM | #9 |
That test was on a 468 cubic inch engine. Can you tell me about your combo? Horsepower, before and after the MAST heads?
09-13-2012, 07:57 AM | #10 |
09-13-2012, 08:54 AM | #11 |
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
here you go
09-13-2012, 12:58 PM | #12 |
http://www.carcraft.com/techarticles...p/viewall.html http://www.gmhightechperformance.com...p/viewall.html As I would expect the stock cam will bare show what the stock rectangle port heads will do much less a set of ported ones. Throw a healthy cam in the mix and its a different story. The intake port on the stock LS3 isnt the problem(as popular cams will show), its the exhaust port. The exhaust port is the first place I would start at to get the best bang for the buck on a port job. I wouldnt see nothing wrong with someone wanting to run a set on the street with just a cleanup on the intake but have almost a full blown race port on the exhaust side.
09-13-2012, 02:52 PM | #13 |
Thanks for the links Bo.
09-13-2012, 02:54 PM | #14 |
