09-17-2012, 02:40 PM | #1 |
Snake Eater
Drives: 2012 AGM ZL1 Join Date: Oct 2011
Applying touch up paint
Can anyone help me through this process? Are there other things needed to make it look it's best? Primer, clear coat, where can I get these items?
09-17-2012, 03:15 PM | #2 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Clean the chip with alcohol, dry it off and get ready. Barely touch the brush to the chip and let it be. Practice on a different surface and do not have too much paint on the brush. Do not let the touch up paint touch the undamaged paint, but let the paint flow to the edges. The key is to be patient and do 6-8 coats to build it up, letting it flash between coats.
You can also use a toothpick or the torn end of a book match to apply the touch up paint.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
09-17-2012, 05:29 PM | #3 |
Snake Eater
No clear coat pen? What do you mean let it flash?
09-17-2012, 10:22 PM | #4 |
Flash is a painters term for "let it dry." Generally flash times are pretty short for auto paints (7-10 minutes). Just read the label on your paint.
09-18-2012, 04:34 AM | #5 |
Drives: 2014 Ford Focus ST Join Date: Jun 2009
Flash in terms with paint's or polishes is like nsane has mention, dry's very fast and very little time to work with.
And go with what Paul SS has mention using a toothpick or the torn end of a book match to apply the touch up paint. That's old school and always work for me and everyone around. Remember to practice before doing it on your paint. |
09-18-2012, 09:23 AM | #6 |
You can also try a magnifying glass to get a bigger picture of where you are placing the paint and make sure you have plenty of light. Rest your hand on the car and roll your wrist and move your fingers to guide the paint.
09-18-2012, 09:30 AM | #7 |
Camaro SL,UTs
Drives: 2010 Camaro SS/RS #16429 Join Date: Sep 2006
Great suggestions. I know that when I do it I use a toothpick and you almost have to remember it's as if you're "filling" in the chip and not actually painting it if that makes sense.
And don't sweat doing a bad job, it can't look worse than the chip... right?
09-18-2012, 10:01 AM | #8 |
Drives: 2012 Camaro 2SS 45th Anniversary Ed Join Date: Oct 2011
The paint and methods ya'll are talking about...is that for the touch up paint from the dealer?
I am thinking of getting some paint, but wasn't sure if that was the best place.
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
09-18-2012, 10:19 AM | #9 | |
Get GM touch up paint from the dealer or Dupli-Color from an auto parts store.
09-19-2012, 03:02 PM | #10 |
Snake Eater
Well so far so good. Still have a good 4-5 more coats to go and then clear coat pen. Where would I purchase one?
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ Follow me on instagram: http://www.instagram.com/snkeatr/ |
