10-03-2012, 03:55 PM | #1 |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
Toyo R888 vs Hoosier R6
I've been running an R888 setup on my camaro for track days, running a 295/19 in the front and a 305/19 in the rear. To say the least, they make a HUGE difference on the track. They provide a ton of grip. My R888's are at the end of their life and I need to buy a new set of track tires. I've been looking at the Hoosier R6. I would want to run a 295/30/19 up front, and a 325/30/19 in the rear. Keep in mind, these would not be for street driving, and just for the track.
How does the R6 stack up against the R888?
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
10-04-2012, 10:46 AM | #2 |
need....more....hp
bump?
10-04-2012, 01:50 PM | #3 |
The R6 is a much softer compound and will not last as long as the 888's but they are incredible once they get some heat in'em. I would not go to R6's unless you have some suspension mods to stiffen things up. You might also find that the off-setting 295/325 will promote a little more understeer.
10-04-2012, 01:52 PM | #4 | |
need....more....hp
10-04-2012, 04:20 PM | #5 |
Drives: 2011 Camaro Join Date: Apr 2012
Have you tried the NT01's or RS-3's?
10-05-2012, 11:25 AM | #6 | |
I run 285's all-around and they are intense on the track. I think some of the Pedders cars are running 305's on all 4 corners |
10-05-2012, 03:33 PM | #7 |
Drives: 1-800-428-8355 X4664 Join Date: Sep 2010
R6-Faster but will wear much quicker. All depends how fast you wanna be.
10-05-2012, 04:27 PM | #8 |
Drives: 2014 Gray Camaro 2LT RS Join Date: Oct 2010
We have compared these tires on a different car and the hoosiers are a much better tire. You won't be disappointed in performance.
2014 Gray 2LT RS, 6M, Eibach Spings, Green Grill Light and Footwell Lighting
