10-23-2012, 01:09 PM | #1 |
Drives: 2010 2SS RS M6 Join Date: Mar 2011
Heater hose replace/relocate difficulty
I've read thru the JDP DYI and all but am still left wondering... how difficult of a job is it really for a guy of average mechanical ability and no lift to do the swap out of the 2010 heater hoses with the 2012 hoses? Getting the old ones off the firewall and water pump doesn't look too bad but frankly I'm a little spooked at the pics of routing them behind the heatshield, lifting the fuel line and evap hose, going around and thru wire harnesses, etc.
Traded-in car: K&N Typhoon intake, JBA Shorty headers, Solo mid-pipes/hi-flow cats, GMPP Track Pack axle-back, Vmax ported TB, Billet Custom catch can, billet tensioner pulley, Hines Hex Vents, Z/TA rear spoiler, ProCustom headlight covers, Drake black/riveted quarter window covers, GM satin fuel door, chrome and brushed caps/covers under the hood, EmblemPros underhood bowtie & fuel rail "Camaro" plates, chrome "SS" door kick-panels, chrome trunk latch plate & strut rods, Street Scene lower grille ducts w/LED lights, front bowtie-delete, Yates Performance pedals, 35% tint, etc.
10-23-2012, 01:13 PM | #2 | |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
She is only memory now. |
10-23-2012, 03:03 PM | #3 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Just take your time, it's not that big a deal. If you have to go somwhere in an hour and don't have another car, don't start it yet.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
10-23-2012, 03:18 PM | #4 |
Can it all be done from above without lifting or even ramping the car?
10-23-2012, 03:58 PM | #5 |
Drives: G5.R Join Date: Sep 2010
10-23-2012, 04:34 PM | #6 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
It is actually pretty easy. Depending on what kind of needle nose pliers you have the hardest part is the hose clamps at the heater core. Once you have the clamps loosened down the hoses I would recommend using a razor blade or box cutter to make a slice in the hoses. This will help them slide off of the heater core pipes.
10-23-2012, 04:39 PM | #7 |
Booooosted.
Yup. Hardest part will be getting the hoses off the firewall.
The heat shield comes loose really easy. The JDP set up fits perfectly. You are supposed to go under the car to bolt/screw a bracket that is on the line in to the car but you don't have to. I did just to be sure it wouldn't rattle but it's up to you. It will still stay in place due to the tab. |
10-24-2012, 10:16 AM | #8 |
Once you have the clamps off the hoses at the heater core a nice long pair of hose pliers with the curved ends work well. Gentle small twists broke mine free very easily.
10-24-2012, 10:58 AM | #9 |
Drives: One of the rare ABM camaros Join Date: Apr 2009
When I changed my heater hoses on my 2010 to the reroute kit, it absolutely sucked to get them off of the firewall. I ended up cutting them.
Dean
2000 5/23 3000 5/27 3400 6/20 TPW of 6/29 3800 7/3 4D00 7/8 interned at QC 4B00 7/16 Released from QC 4200 7/20 8/5 We picked up the car |
10-24-2012, 11:41 AM | #10 |
Hating prius's since 1997
Drives: 2010 Camaro 2SS/RS (JENNA) Join Date: Apr 2011
I have the GM kit and have for a while but was always afraid to do this also. Biggest thing for me is I didnt want a huge coolant mess everywhere.
PIPE
10-24-2012, 11:50 AM | #11 |
Drain about a gallon or so out of the radiator and be prepared with rags or small containers when you remove hoses (water pump end first) it won't be to messy at all.
10-24-2012, 12:01 PM | #12 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Had to slice existing hoses off, I really tried not to do it. Definitely get the correct pliers for the clamps at the firewall, I didn't and I struggled. I used gates hoses for replacements. Had Issues with burping the system on the refill.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
10-24-2012, 12:41 PM | #13 | |
I'm sure I'll go ahead and do this mod fairly soon. I've done (on a previous car, my 2005 Impala SS) an intercooler install, valve rocker swaps, lowering spring install, etc, etc, all of which spooked me at first but after studying and thinking/planning for a while and then plunging in they all ended up fine. Sometimes not without a lot of swearing and wrench tossing but overall successful.
10-24-2012, 03:16 PM | #14 | |
http://www.harborfreight.com/3-piece...ers-37909.html
