11-03-2012, 05:53 PM | #1 |
Drives: Camaro SS Join Date: Nov 2011
Getting my winter tires tomorrow, need help
So I have a 2010 SS with RS package, with the stock 20" wheels and summer tires(245/45 front 275/40 back I believe). Recently I got a set of 19" and pirelli scorpion snow and ice for the winter(without tire pressure sensor). My question is, is it possible to swap the wheels myself? The winter ones are already balanced and fitted onto the 19s. How is the tire pressure sensor connected to the car? How do I disconnect it? I know the tire lights will be up all winter on the 19s, and the speedo will be inaccurate. Are there anything else I need to know? Pepboys guys said they can do the swap for $20 since the tires are already on the rims, should I just ask them and skip the trouble or is it a simple jack up and unscrew?
Also I am aware that the pirelli summer tires don't last very long, how about the pirelli scorpion snow and ice? What would be a good substitute when my current set run out? This car is my only DD and I only do about 12k driving per year. I don't bring it to the tracks but I do rev it to 4.5k on straight highways. Price isn't a huge concern as long as the new set can last a bit longer than the stock ones. Thanks a lot ^___^ sorry about the long winded questions, this will be my first winter with the SS so I'm a bit worried...... Last edited by ps2ren; 11-03-2012 at 06:19 PM. |
11-04-2012, 09:20 AM | #2 |
Drives: 2011 2SS RS, 1968 ragtop Join Date: Apr 2009
Yo, I just threw on my winter tires/wheels yesterday.
Just jack the car up in the air safely and put them on. Loosen the lugs before you put it in the air. I personally jack it one corner at a time and make the swap. I've had shops swap them for me, but it actually takes longer (drop off the SS, shuttle home to load up the winter tires in another vehicle, drop off at shop, shuffle the cars again). You may not get an error on the TPMS. It'll will likely still show the readings from your summer tires. The Snow and Ice Pirellis will last you a long time if you take care of them. You'll only have them on the car for a few thousand miles/year more than likely. Mine are going on their 3rd winter with no visible wear.
1968 Camaro Convertible LS1, T56
11-04-2012, 09:59 AM | #3 | |
Drives: 2017 RS convertible Join Date: May 2009
Hope that helps...
Camaros I've owned:
1969 RS/SS Z10 Indy Pace Car - Hardtop 1 of 250 1970 Camaro 2010 2LT RS 2013 2SS RS Current ride: 2017 Camaro 2LT RS convertible |
11-04-2012, 10:41 AM | #4 |
Oh cool~ thanks for the help ppl~ I will have a friend driving the tires around with an SUV so moving them isn't a problem. I will look into touring tires when the summer ones run out
11-04-2012, 09:56 PM | #5 |
Drives: 2013 1LE AGM 2SS RS M6 Join Date: Apr 2012
Hey ps2ren, I am in Philly to! any suggestions for winter tires in this Philly weather?
11-05-2012, 06:22 PM | #6 |
Drives: 2013 Camaro 2SS/RS Join Date: May 2009
Why don't you just load the tires in your Camaro? One slides in the trunk through the back seat and other three fit in the back seat with the passenger seat tilted forward. I've done it lots of times.
Then: 2LT/RS Black/Black auto w/sunroof
Now: 2SS/RS CRT/Black auto w/sunroof |
11-05-2012, 07:21 PM | #7 |
Drives: 2012 Camaro 2SS LS3 Ashen Grey Join Date: Mar 2012
Do you guys get your cars re-aligned every time you swap out the tires?
2012 2SS/RS, Magna TVS2300, RX Catch Can, Borla S-Type, Pfadt Stage 4 w/ ZL Spec Sway Bars, ADM Custom Boost/AFR Gauges, Hurst Short Throw, Forgestar F14 Matte Black 20x11 & 20x9.5 Deep Concave all 4, Nitto Invo 315/35 & 275/40, Heritage Grill, Sparks Black Grill SS & Trunk SS, P13W Fog Lights (cool white) w/ DRL Harness, Blacked Out Brake light bezels, Xpel Smoke Light Kit
11-05-2012, 07:24 PM | #8 |
I swapped tires every spring and fall for 3 years and never needed to
11-06-2012, 11:49 AM | #9 | |
Hi, this is the first time I'm dealing with winter with the camaro too...... I got the pirelli scorpion ice and snow some people mentioned on this forums. They are on the expensive side but should be similar to the stock tires
11-06-2012, 12:01 PM | #10 | |
When I upgraded to the SS I sold those tires with my RS since they wouldn't fit on the SS. I just ordered new 20" wheels with the Dunlop 3D Sport winter tires.
11-06-2012, 12:12 PM | #11 | |
11-06-2012, 03:28 PM | #12 | |
Drives: 2SS/RS Join Date: Sep 2008
Another option you could have is just not install the TPMS. You will get a warning light but it won't harm anything to go this route for a couple months. |
11-06-2012, 03:29 PM | #13 | |
I have a feeling that stock SS without RS package come with spacers, I wonder if anyone knows about that on here
11-06-2012, 03:40 PM | #14 |
Drives: Car Join Date: Sep 2012
No one ever said how the sensor is connected to the car. Will there be a plug coming out of the wheel or something?
