Airborne Pathfinder
Drives: Camaro ZL575 Join Date: Nov 2009
Exhaust
Myself and a couple of friends installed a complete maganflow exhaust from the cats back, every bump I hit it hits the crossbar where the resonator used to be, it is driving me and the wife nuts.
I went by a local mufflet shop and he said it was tight and not much I could do, ANY THOUGHTS!
2010 Camaro Indy 500 Pace car, LS3-ZL575
Other cars are- 95 BMW 325 sedan- AA exhaust, AA CAI, AA Strut bar, AA chip, M3 rotors and calipers, racing clutch, oversized injectors, upgraded M3 interior- Audi A4 SLine, with black out optics |
Do you even lift, bro?
sell the car.
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461 |
![]() ![]() ![]() Drives: 2010 SS L99 Inferno Orange Join Date: Apr 2012
Need to put a spacer of some kind ( or a stack of washers ) on the crossmember! This should lower the crossmember where it doesn't hit the pipe! Don't worry,it can be fixed!good luck!!!
![]() ![]() ![]() ![]() Drives: 2012 AGM SS Join Date: Jun 2012
There's a spacer included with the Stainless Works Retro Catback to solve this. It's a plastic washer made to go between both sets of screws for the tunnel brace. Maybe one of the vendors can chime in on exactly what it is or how to get one specifically.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 Seconds or Faster Join Date: May 2012
There are braces made for aftermarket exhausts, or you can do what I did, and throw a nut on each corner. I went with the nut just because I thought that being threaded it would hold better, but washers work too.
#6 |
Airborne Pathfinder
not a bad idea, thanks
#7 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
It's not that it isn't tight but that it wasn't pushed up THEN tightened. Very common problem with pretty much all catbacks. You'll have to loosen the connections, push up on the pipes, then retighten. When it settles, it may or may not hit anymore. You can also use washers to lower the tunnel brace. I like washers since you can add just what you need. As long as you have 3/4-1in clearance, it should be fine.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
