11-07-2012, 05:41 PM | #1 |
Drives: 2011 5.7L Tundra Double-Cab X-SP Join Date: Mar 2012
DDM Tuning HID kit help
Hey guys, I bought a 9006 kit from these guys to use as a test on my wifes Envoy before I put a kit in my car. I've hooked them up and neither one works at all. I was wondering if maybe I missed something.
After that failed I did a 'direct to battery' test and they still won't do anything. I know the 9006 isn't for our cars but I plan on using DDM for my Camaro too so maybe it is appropriate in this section. Has anyone used DDM and have any tips or suggestions on how I can get mine to work? Maybe I did something wrong lol. The connectors from the ballast to the bulb are set-up so they only connect one way so I can't imagine I wired anything wrong. |
11-07-2012, 05:53 PM | #2 |
650HP soon to come
Drives: 2017 Chevy Camaro ZL1 Join Date: Jul 2011
I ordered a kit from DDM tuning on my Colorado when I had it. Alot of GM vehicles require you to flip the wiring because of reverse polarity.
Notice on this kit the two black wires are not together. This was my DDM tuning kit use this info for assistance as well: http://www.ddmtuning.com/support/ind...kbarticleid=20
2017 Camaro ZL1
Hyper Blue Metallic A10, PDR, NAV, Premium floor mats |
11-07-2012, 06:14 PM | #3 |
Drives: SSICKO Join Date: Jul 2010
I used to have a Trailblazer SS which is the same platform as the envoy search on www.tbssowners.com how to install HIDs on these vehicles, there is special wiring that you have to play with under the back seats...its a simple fix, i did it 4 years ago when i had it an never had one problem. i wish i could help you more but im getting you off to a good start with that site. good people over there
Slowhawk Performance Built & Tuned
11-07-2012, 07:43 PM | #4 |
That Cam though...
Drives: 11 Camaro 2SS 02 T/A WS6 15 SSV Join Date: Mar 2010
ya I have them on my hhr. check the polarity like blue said. my kit been on a year no problems and bright.
11-07-2012, 11:12 PM | #5 |
Thanks for all the help guys!
11-08-2012, 04:32 PM | #6 |
I'll try to reverse it, but if I clamped two wires off on the inside of the bulb socket prongs (where it would plug into the bulb normally) and then ran it to a battery they should work right?
I guess I'll have to cut them and reverse them? |
