Most hated in NM....
Drives: Sold the 6POINT2, went to a 50THZ06 Join Date: Sep 2011
New NHRA rules?? roll cage
Just wondering exactly what this might mean for me? Does this mean that I don't need a roll cage?
My main question would be Does "unaltered" refer to suspension or mean totally stock, I.E. stock power train? NHRA DRAGS: STREET LEGAL STYLE PRESENTED BY AAA (Page xiv) (5th paragraph) Additionally requirements and specifications for Street Legal are the same as those for the Summit Racing Series with the following exception: Unaltered 2008 OEM model year and newer production cars running slower than 9.99 and 135 mph do not have to meet the requirements and specifications for the Summit Racing Series except for the following: Convertibles and T-tops must meet Summit Racing Series Roll Bar and Roll Cage requirements, All drivers must meet the Summit Racing Series Helmet and Protective Clothing requirements. http://www.nhra.com/UserFiles/file/2...Amendments.pdf
![]() Drives: 2010 RS 2 SS Join Date: Aug 2009
lets hope so . i don't want to cage my car either . 10.75 @ 128 for my new best , so i'm close on the mph side of the rules
![]() ![]() ![]() ![]() ![]() ![]() Drives: none Join Date: Aug 2011
...I heard about this the other night and was hoping someone could shed some more light on this?
![]() Drives: 2010 Camaro SS Join Date: Jun 2012
By "unaltered" I think they mean that if you have a 2010 Camaro with a "Factory" block, then you are good. But if you have a 2010 Camaro with a 454 and a 9" rear end, then you probably are no longer within those guidelines. Now that "Factory" block could be built. I think that is what they are getting at.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
Or do they mean cars like a zr1, viper, etc that run faster than that bone stock and any mods at all, means you still need a cage.
135mph still screws me over but if I could get the wife's car to go 10s without a cage I would be happy.
Nick
Corvette Z06 -1200ish rwhp |
#6 | |
oh well, I planned on putting a cage in this winter so I will just continue to do so.
#7 | |
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS & 2008 C6 Join Date: Mar 2008
Can anyone shed light on this, thats going to be pretty important exactly what they mean by unaltered. does that mean factory block and drivetrain, or does it mean bonestock? Any idea`s on how to find out? I`m in the same boat, do not want a cage and can only go to track rentals where they look the other way.
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s! Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list.. |
#9 | |
would not be hard to get a ZL575 badge...or ZL1 badging. How many homers at the track will know the difference.. Just sayn...
#10 |
So from reading the below: it looks like if you have a supercharger you are out if you have an SS. ZL575 or ZL1 you are golden. Will be looking for my badging shortly...
SECTION 10A: STOCK CARS, ENGINE:1, ENGINE (Page 3) Must be same year and make as car used, aftermarket NHRA accepted cylinder blocks permitted. Equipment other than original factory-installed prohibited. Any special equipment export kit (superchargers, dealer-installed options, etc.) automatically disqualifies car. Engine must remain in stock location — height, setback, etc. Cylinder bores must not exceed .075 .080-inch over stock. Bores are measured at top of cylinder where ring wear is not evident. Crossbreeding parts prohibited. Normal balance job (i.e., one piston/rod assembly untouched) permitted. Otherwise lightening of component parts prohibited. All carburetors, manifolds, heads, etc. must be tightened to prevent any air or fuel leaks. Vacuum lines must be securely connected or blocked off. Stroke tolerance is +/- .015-inch. Stock OEM crankshaft mandatory. Stock OEM or NHRA-accepted aftermarket crankshaft mandatory. Aftermarket crank must retain OEM configuration; (i.e., billets, knife edging, etc. prohibited). Lightening of crankshaft other than normal balance job prohibited. Cylinder blocks may be sleeved. Aftermarket SFI Spec 18.1 harmonic balancer mandatory in AAA/S through G/S and AAA/SA through G/SA. See General Regulations 1:2. SECTION 10A: STOCK CARS, DRIVETRAIN:2, TRANSMISSION, Automatic (Page 6) Any model transmission, same make as car, with a maximum of three forward speeds (unless OEM equipped with more than three forward speeds). (must be same make as car) having same number of forward speeds (O.D. gear not required,) and reverse permitted. Transmission case must be OEM or aftermarket OEM replica from a standard, automotive application as found in the Official NHRA Stock Car Classification Guide. Aftermarket case must meet SFI Spec. 4.1 and 30.1. NHRA-accepted adapter plates permitted. Modifications to shifting patterns are permitted, provided full shift pattern is retained. Full shift pattern must include park and reverse. Any gear change must occur as a result of an internal function of the transmission or from direct action by the driver. Lockup converter permitted if OEM-equipped with lockup converter and OEM transmission is used. Otherwise, lockup converters prohibited. Electronic rpm controls for the electric (internal or external to the transmission) shifting of automatic transmissions permitted in computer-controlled vehicles only. Otherwise, any gear change must occur as a result of an internal function of the transmission or from direct action by the driver. Pneumatic, hydraulic, electric, etc. controls and shifters in all non-computer controlled electronic-fuel-injected vehicles prohibited. Deepened stock or aftermarket transmission oil pans permitted. Drilling of transmission case or rear of engine block to adapt incompatible units prohibited. Functional neutral safety switch mandatory. Transmission brake prohibited. Tailshaft modifications for bushing replacement, or NHRA-accepted aftermarket tailshaft, permitted. See General Regulations 2:12, 2:14. SECTION 10A: STOCK CARS, INTERIOR:6, UPHOLSTERY (Page 9) Must have full factory-type upholstery for year/model claimed, including factory-type floor mats or carpet, door panels and headliner, and front and rear seats. Interior gutting prohibited. Driver’s seat tracks may be bolted down. Sun visors optional. Rear seat may be removed when roll bar is installed; area must be carpeted or upholstered equivalent to factory specifications (no bare paneling). Full-size aftermarket or corporate OEM front seats permitted; must be upholstered and supported. See General Regulations 6:2. SECTION 10A: STOCK CARS, DRIVER RESTRAINT SYSTEM (Page 11) Three-inch driver restraint system meeting SFI Spec 16.1, including crotch strap, mandatory in classes AAA/S through AA/S M/S, AAA/SA through AA/SA M/SA, all convertibles, and in any car running 11.49 or quicker. Restraint system must be updated at two-year intervals from date of manufacture. See General Regulations 10:5.
#11 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS,LS3 Join Date: Oct 2010
That sucks
LS-3, ProCharger D1SC ![]() 665. rwhp /562. rwtq @ 9.3 psi |
#12 |
ZL575s wouldn't count. Those are just modded cars from SLP. Would be no different than anyone else bolting a maggie on. ZL1s would count but the odds of them running faster than 11.5 bone stock is pretty much non-existent.
Nick
#13 | |
![]() ![]() ![]() ![]() Drives: ZL1 Camaro Join Date: Feb 2009
#14 |
I still don't think you guys are any closer to the truth. I'm pretty sure that the rules above are referring to the stock car classes.
NHRA stock car The amendment above is referring to Street Legal. |
