Old 12-04-2012, 02:28 AM   #1
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
Trunk seal TSB?
There are several reference in the forum to the damage to the trunk seal where the cable release conduit rubs a half circle in the rubber. The damage occurs near the passenger side trunk hinge. Does anyone know if there is a TSB or the TSB number (if there is one)? My dealer is going to replace the seal but couldn't find the TSB to reference any modification. Appreciate any help.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 12-04-2012, 07:07 AM   #2
'11 cyber grey vert
"SHARK" Born Apr.26,2011
'11 cyber grey vert's Avatar
Drives: 2011 CGM 2LT/RS Convertible
I had my trunk seal replaced last year by my dealer.There wasn't any tsb at the time, but what my dealer did was attach a little clip to pull the cable away from the new trunk seal.No problems since.
'11 cyber grey vert is offline   Reply With Quote
Old 12-04-2012, 09:33 AM   #3
He11bent
He11bent's Avatar
Thanks Shark.
Sound Tube Delete
Old 12-10-2012, 01:25 AM   #4
He11bent
He11bent's Avatar
Wow...a bit surprising so ...I guess there isn't one. I do appreciate every taking the time to read the thread though!
Sound Tube Delete
Old 12-10-2012, 02:59 AM   #5
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Can ya post a pic of this fix?
tramtwo is offline   Reply With Quote
Old 12-10-2012, 09:49 AM   #6
'11 cyber grey vert
Sorry tram, can't post pic , my vert is in winter hibernation
Old 12-10-2012, 09:51 AM   #7
Falundir
Falundir's Avatar
Drives: 2017 1SS 1LE - Hyper Blue, P85DL
Same thing here.
I will post a picture when I get back on Saturday.
Falundir is offline   Reply With Quote
Old 12-10-2012, 10:41 AM   #8
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Thanks and I doubled checked and I will have this problem on this 2013 coupe. When the trunk opens the seal gets pinched by the wire bundle.
Old 12-11-2012, 03:30 PM   #9
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
I would think if you just undid the plastic retainer nearest to the opening it would give plenty of wiggle room to avoid rubbing the trunk seal.
9/26/09 Took delivery!
Old 04-11-2013, 02:40 PM   #10
LessSinister
Drives: 2011 - 2LT/RS Convertible
Originally Posted by Falundir View Post
Same thing here.
Just had mine replaced and the dealer attempted to move the cables to the right a bit but it's still rubbing (just further to the right now) so would appreciate pics of what your dealer did that actually worked.
Thanks in advance. Worst case, may have to undo that first clip as V6Sonoma suggested.
LessSinister is offline   Reply With Quote
Old 04-11-2013, 08:22 PM   #11
pnyklr
Drives: A Gift From My Wife
No official TSB but here is what is coming from the factory as a resolution. ATM, there is no PN for that clip.
-Funk
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping.
08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery).
08/16/2011 - (5000) Vehicle has been delivered to dealer.
08/19/2011 - In my possession.
pnyklr is offline   Reply With Quote
Old 04-12-2013, 01:38 AM   #12
decepticon-vert
decepticon-vert's Avatar
Drives: 2011 Camaro 2LT Convertible
Send a message via Yahoo to decepticon-vert
My vert is in dealer for the same thing. Let's see what they do. However cable tore seal on mine. Once I get it back I will update.
There's a difference between knowledge and wisdom..
decepticon-vert is offline   Reply With Quote
Old 04-12-2013, 02:28 AM   #13
LessSinister
-Funk
I'm not sure how that clip helps as the whole conduit moves up and down as I open and close the trunk. It seems there isn't enough slack in the conduit to prevent it from catching or rubbing on the upswing/opening. Anywho, I'll show this to my dealer and see what he says.
Thanks.
P.S. did this fix the issue for you?
Old 04-12-2013, 10:09 AM   #14
Chevrolet Customer Svc
Drives: GM Vehicles
LessSinister,
Sorry to hear about your concerns, but I'd be happy to schedule an appointment at a Chevrolet dealer near you for an official GM diagnosis to sort this issue out. Would you mind private messaging me your VIN number, the vehicle's mileage, and your zip code?
William R.
Chevrolet Customer Care
