12-08-2012, 05:39 PM | #1 |
Drives: 2011 Blue1SSRS 623RWHP, 02 vette Join Date: Aug 2010
injectors??????
what is the big difference between
FAST LS3/LS7/L76/L92/L99-Type 85 lb/hr (892.5cc/min) Fuel Injectors =$395 and ID 850's other than the ID 850 are twice the price.= $920 I know lots of people run the FAST one with no problems. Sooooo why are they worth that kind of difference in price? tuning? if so why would that mater to the end user. power? longevity? just tring to figure this one out????????? THANKS!
2002 Vette (stock)
Team LS-3 |
12-08-2012, 05:51 PM | #2 |
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6 Join Date: Dec 2011
12-08-2012, 05:59 PM | #3 |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
I imagine the fasts can be made to work well by a good tuner, but I have seen instances where they were never made to run perfectly. With I'D's that doesn't seem to be an issue because of the correct data being available. When I switched mine tuning was easy to get right. Even by me and I'm far from an expert.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
12-09-2012, 08:21 AM | #4 | |
99% of aftermarket injectors are only checked at Full Flow and sold that way i.e. 60 lb or 85 lb etc. This tells you Nothing about what that injectors flow at Idle. The money you save by using cheap injectors will cost 4 times more to get it right in tuning cost if the tuner Really spends the time necessary to get everything right and it will still never be perfect. WIDE open tuning is the Easiest part of the tune. Idle, cold start, hot start, Power enrichment, Throttle transition fueling, are the hard things to get right when you guessing at injector data. ID-850 are manufactured, tested, and Verified to some ridiculous low Percentage of error, and then come with all the RIGHT injector data to load in your tune file which leaves your Tuner to deal with MAF and Timing to deal with. Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com Last edited by JANNETTYRACING; 12-10-2012 at 08:24 AM. |
12-09-2012, 08:50 AM | #5 |
Thank you Ted,
2002 Vette (stock)
Team LS-3 |
