Old 12-24-2012, 06:34 AM   #1
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
Need help with decision
Im going to detail my Z within a couple weeks and I was wondering what kind of polish, glaze, swirl remover that I could use with the griots 6 inch buffer with Lake county pads. Im in the final decision stage, Im leaning towards using Meguiars #9, 3, 5 to give my Z that deep shine. Any thoughts on these products? Im choosing meguiars because I can receive it local and it is cheaper than Adams products and shipping. Thank You
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 12-24-2012, 02:14 PM   #2
Iomcamaro
The enjoyment never ends
Iomcamaro's Avatar
Drives: 2010 1LT/RS IOM #25223
M105 followed by M205.
Iomcamaro is offline   Reply With Quote
Old 12-24-2012, 05:16 PM   #3
EvilZL1
Snake Eater
EvilZL1's Avatar
Isnt 105 a but aggressive on the paint?
Old 12-24-2012, 05:55 PM   #4
David79z28
David79z28's Avatar
Drives: 79Z28 and 2010 2SS/RS
You can effect it's aggressiveness by using different pads. Try a test spot with a white pad.
If that doesn't work after a couple of passes, change to an orange pad.
Test with the 205 on different pads also. Use the least aggressive method to get the job done.
You will get faster results with less products using the 105/205.
The condition of your paint will determine how aggressive you need to get.
David79z28 is offline   Reply With Quote
