Convertible Exhaust
So I have a 2012 2SS Convertible with GFX body kit.
What are my options for aftermarket exhausts? I really like the Borla "s" type, but it is rather pricey and not sure if it fits.
2018 2SS hot wheels convertible
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
I know that GM had optional axle-back exhausts for 2011 for both with GFX, and without GFX. I had it on mine (no GFX) and loved it.
RIP - Convertible SS
Drives: '13 Mustang Boss 302 - RED Join Date: Apr 2011
I have the Solo Performance Mach-XC (the "C" is for convertible).
Question: Do you plan on adding headers at some point? I have headers and the Solo cat-back exhaust and I think it's a bit too much rumble. I cringe every morning when I start my car....tough to be my neighbor! Loved the Solo exhaust before headers, but if you plan on adding headers, consider staying with the stock exhaust. The stock exhaust is good, just no rumble. Adding headers will add the rumble and performance. If you want rumble and will never add headers, I think you'd like Solo. |
#4 | |
![]() Drives: 2013 Camaro SS Convertible Join Date: Nov 2012
I really want better sound, but was saving headers for later because I figured they would cost more and require a tune. I dont want to end up with too much rumble in the end, though. Sorry if I threadjacked here... good info! |
#5 | |
Again - I think the combo of catback exhaust and headers is too much rumble, esp for a convertible. If I had to do it over again, I'd stick with stock exhaust (which is a very good exhaust) and just let the headers add the rumble. If I were you, I'd save up for headers and a cold-air intake (if you don't have intake yet) and install/tune them together. Headers, CAI, and stock exhaust will have plenty of growl. You are going to get TOO MUCH advice on headers. "Buy X because of Y. Don't buy Z because the tubing/pipe is made in China." In the end, do a bit of homework and spend/buy what you are comfortable with. My Texas Speed Headers (at $799) make as much power as Kooks or American Racing (at $1600). Could I afford Kooks or AR? Yep..... but why spend the extra $$. My installer said the Texas Speed headers installed as easy as any headers he's put on a Camaro. |
#6 |
![]() Drives: '11 Camaro SS Conv. + '06 Silverado Join Date: Apr 2011
I literally just ordered the Solo Axle back for my 2011 vert. Can't wait for the install!
Riding the Storm out!
#7 |
![]() Drives: 2012 Camaro 1SS/RS Vert Join Date: May 2012
Jonster - I have the BORLA "S Type" Touring. The tips will not fit the the GFX holes in the Rear, so I left mine off and painted the pipe black. I'll forward you som pics later. It sound awesome! I don't regret putting it on. They are worth the money...
Good luck
CDC Sports Bar, CAI Cold Air Intake, Footwell & Cup Holder LED's, Borla Catback Exhaust and Pfadt Stage II Suspension Kit, Black Taillight Bezels, MGW Short Shifter, LED Door Sills, T3 Bumper ports w/Mesh, Heritage Grill (Black), 3D Carbon Front Side Panel Vents, ZL1 Hood Insert (Flat Black Carbon Fiber).
#8 |
![]() Drives: Inferno Orange 2SS RS Convertible Join Date: Aug 2011
SLP Loudmouth II.
#9 | |
#10 |
Treasure Coast Camaro 5
Drives: 19 2SS vert, Mosaic Blk, A10 Join Date: Feb 2009
Sound and quality are a personal preference. I wanted loud and deep; I went cat back and got deep but subtle. Added headers and got loud and raspy. Not really I wanted, but turns a lot of heads and screams "muscle car."
There is a difference between standard exhaust and gfx systems, basically it comes down to the constricted size of the bezels in the gfx. Systems such as the Borla S or Atak simply cut off the tips and end with a shortened 3" pipe inside the bezel... the idea is to make the bezel look like a large tip. The stock exhaust tips will fit inside the bezel if you have or can get a hold of a set. However if you go without cats on the headers; the added heat will melt the plastic around the bezels (speaking from experience.) The majority of company make specific kits for the gfx kits; and its simply a different tip option. You can buy the MBRP square tips which fit perfectly inside the bezel, or find other options (I went with a dual 2.5" tip for each bezel) if you don't like the recessed look. My set up (Magnaflow Competition, no cats, Stainless Works headers) sound very aggressive; but no where near what id consider "too loud." The Magnaflow by itself had a great deep growl, but only.under throttle. Near stock sounding at idle. Loved the tone, but the headers really added the volume. Dramatic change to the tone as well.
#11 | |
Sent from my DROID RAZR using Tapatalk 2 |
#12 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
I've contemplated adding LT headers, but I've held off for fear they will make the car too loud. Plus I'm not quite ready to void my powertrain warranty. I will probably add Solo's HFCs early next year. Even the addition of HFCs has me concerned that it will tip the balance to the side of too loud.
#13 |
![]() Drives: 2013 2ss/rs Join Date: Dec 2012
I just ordered a 13 ss drop with the dual mode exhaust.
How does that sound compared with all the aftermarket options? It's winter where I am and I haven't heard one with the dual mode. |
#14 |
I test drove one and it sounded good. If I had it I wouldn't feel the need to upgrade it.
