01-05-2013, 04:04 PM | #1 |
AEM Tru boost gauge
I have a turbonetics kit on my ls3, I am thinking about getting this gauge. For anyone that has experience with this setup, the wastegates are external on the system. How do I run the hoses to both gates? Just install a y after the boost solenoid? Also why do they make an extra boost gauge that uses the three pin plug on the gauge? Doesn't the hose coming off the gauge already read boost/vacuum?
01-06-2013, 07:30 PM | #2 |
Drives: 1969 camaro SS;2011 Turbocharged SS Join Date: May 2012
Bump...I'd like to find out too?
2011 turbocharged SS Borla Touring Axle back |
01-06-2013, 07:38 PM | #3 |
Drives: 2010 rs/ss black # 10,308 Join Date: Mar 2009
I thought the turbinetics kit has one Turbo? If you have two then yes you should run a "T" adapter after the solenoid. As far as the wires coming off of it. They put those on for an external logger just in case you want to log your boost.
If you also go on their website you can download the full instructions which explains what each wire and plug is used for. sent from my galaxy s3. that would explain the errors.
01-06-2013, 10:23 PM | #4 |
Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
The way I have it wired is with a "T" on the line that comes from the compressor cover with one end going to the solenoid than the other end is "T'd" again with one end going to the bottom of one WG and the other end to the bottom of the other WG. Then another line from the other side of the solenoid with another "T" which then goes to the top of each WG.
The wires coming out of the solenoid are hot and ground that go to the gauge.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo |
01-06-2013, 10:34 PM | #5 | |
01-06-2013, 10:38 PM | #6 | |
01-07-2013, 09:14 AM | #7 | |
but anyways the 3 pin connector is an optional add on if you want to read boost levels up to 75psi. I believe the internal one on the actual gauge only goes to 30psi.
01-07-2013, 10:55 AM | #8 | |
Yes, I think you should only have the BOV and one WG. The solenoid should only have two wires a Red and a Black. The gauge is the one with a Orange(scramble boost) and a Grey(optional warning light). You can use the Orange wire to reduce boost to WG pressure or to increase boost to higher than WG pressure at the flip of the switch. I have the Orange wire hooked to the water/methanol kit so if it faults for any reason(low on meth, pump failure, clogged nozzle etc.) it will reduce boost to WG(low 7-8psi) pressure.
01-07-2013, 11:02 AM | #9 | |
The electric boost gauges have an external MAP sensor the reads vacuum/boost and sends the info electronically to the gauge. The mechanical boost gauges have a nipple that gets "T'ed" to a your vacuum/boost reference.
01-07-2013, 11:11 AM | #10 |
I just checked and sure enough it does come with two WG's. In order to be smog legal they worked off the stock exhaust and added hot pipes after the cats. Each pipe after the cats has a WG then they come together before going into the turbo. After the turbo they again separate and go into the stock exhaust again. Whole lot of piping.
01-07-2013, 11:33 AM | #11 | |
01-07-2013, 04:06 PM | #12 |
Yep two wastegates like srt said, the bov is mounted to the top of the ic.
01-07-2013, 04:12 PM | #13 |
I was looking at my car today and the wastegate has a line going into the bottom that obviously is sending the boost pressure so it know when to open up but the there is no line in the cover. There is the hole for it but nothing is there, why is that?
01-07-2013, 04:21 PM | #14 |
That one vents to atmospere. Do not plug the line to it or you will overboost. If you get a boost controller then you will use that port.
