Old 01-07-2013, 04:10 AM   #1
amphi
Drives: 2SS Imperial Blue
GM approved undercarriage paint?
Hello,
Did an oil change and saw that my Camaro is getting older. A couple of rust spots on the suspension and undercarrage. Probably from rock chips going 140 down the autobahn.
Is there a part number for the "black" paint that GM used in the factory? If not, is there a good substitution? Thanks.
amphi is offline   Reply With Quote
Old 01-07-2013, 04:46 AM   #2
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
PlasticKote semi gloss in a rattle can.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 01-09-2013, 09:41 AM   #3
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
Black Epoxy Primer
PPG DP90LF with DP401LF Catalyst. Sand to clean metal first. Can be brushed or sprayed. Wear a respirator, particularly if spraying. Cosmetically spraying is the way to go. For corrosion resistance, it doesn't matter.
chef-beavis is offline   Reply With Quote
Old 01-09-2013, 11:09 AM   #4
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
Check out Eastwoods, they have lots of that stuff.
MMC is offline   Reply With Quote
Old 01-09-2013, 10:01 PM   #5
MustangKiller
MustangKiller's Avatar
Drives: 2013 2ss/rs A6 yellow !!!!!
Is that the exact paint they spray on the suspension and cradles
MustangKiller is offline   Reply With Quote
Old 01-09-2013, 11:16 PM   #6
SimpleGreen
Drives: 2015 2SS/RS
Rustoleum! Or whatever the equivalent is in your neck of the woods. Has worked extremely well on my beater truck...
2015 Camaro 2SS/RS SIM
2016 Jeep Wrangler 2DR Willys Wheeler
1993 C1500 Single Cab Stepside 5.3L LS Swap
SimpleGreen is offline   Reply With Quote
Old 01-09-2013, 11:38 PM   #7
mulletman
Drives: 2017 Camaro SS
Clint is a crazy bastard.
mulletman is offline   Reply With Quote
Old 01-10-2013, 01:20 PM   #8
David79z28
David79z28's Avatar
Drives: 79Z28 and 2010 2SS/RS
Hammerite rust cap paints are available in spray cans or quarts.
It can be applied over rust and is tough!!!!
http://www.hammerite.com/
David79z28 is offline   Reply With Quote
Old 01-10-2013, 01:56 PM   #9
chef-beavis
Not sure, but the PPG stuff is a dead ringer and will hold back corrosion better than rattle can stuff. The stuff from the factory is likely a dipped ELPO product like the bodies generally get. No real way to duplicate that in your garage.
http://www.fourwheeler.com/techartic.../photo_09.html
Old 01-12-2013, 10:54 AM   #10
MustangKiller
Im talkin about the black subframe paint maybe epoxybased?
Old 01-12-2013, 05:06 PM   #11
chef-beavis
PPG DP90LF is epoxy primer.
