01-15-2013, 10:55 AM | #1 |
Drives: 2013 VR vert ZL1 Join Date: Aug 2012
Wonder if I can get these zl1 replicas widened
I would like to get the 20x8.5 widened to a 20x10.5 and put the 20x9.5 in front. Is this possible? |
01-15-2013, 11:18 AM | #2 |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
Nice deal, and I am sure you can! If it were me I would leave them and run a 275 tire on front and a 305 on the rear. You would be fine.
10.91 at 122 H/C stock block N/A
01-15-2013, 11:54 AM | #3 |
Ohh I didn't know I can run a 305 on a 9.5. Yea in that case I would just leave them as well. Thanks for the heads up
01-15-2013, 11:57 AM | #4 | |
These would be sweet then |
01-16-2013, 08:52 AM | #5 |
Its not all that recomended but many people do it! For auto X I would not, but for a drag radial your fine. I am putting 305 nitto 555rs on my car in a few months on the stock rear 9"s. The nittos run a little small and tons of people have done it on there SRTs and SS's and loved the outcome! So with a 9.5 your fine, you might want to look at the nitto NT05 also... if the 555r runs a bit small that one might to.
01-16-2013, 11:03 AM | #6 |
Drives: Camaro Join Date: Aug 2012
What's the point of spending more money on a wider tire that's not going to improve but in fact hurt performance?
On a 9.5" wheel a proper fitting 275 tire will have just as much contact patch as a 305. The 305 is heavier, more expensive while not offering any wider contact patch to the ground. So why again? You can always send out the wheels to weldcraft wheels and have them add some width to them. Otherwise I wouldn't run more than a 285 on a 9.5" wheel and a 255" on a 8.5" wheel. |
01-16-2013, 11:40 AM | #7 | |
The 275 is on the small side for a 9" rim, my 295s look and fit WAY better! Like I said, I would not go this route with a car thats setup for tight corners, but for a drag radial its fine!
01-16-2013, 01:00 PM | #8 | |
01-16-2013, 01:26 PM | #9 |
I guess... You keep your 275s and the other thousands of stupid people like me will have a wider, sticky, and better looking tire on there stock wheels If you seen my car is person it might change your mind! If I listen to every manufacturer and what they recomend I would still have a boring stock car! to each there own.
