Old 01-26-2013, 08:08 PM   #1
Michael2000
Drives: .
Does 1LE Have Speed Governor?
Since the 1LE uses the ZL1 front tires on both front and rear, and the ZL1 does not have a speed governor, anyone know if GM removed the governor on the 1LE?
Michael
Michael2000 is offline   Reply With Quote
Old 01-26-2013, 08:11 PM   #2
Austin45
The Logistician
Austin45's Avatar
Drives: 2012 LFX 45th Anniversary
The 1LE has the governor. The only Camaro without it is the ZL1.
Austin45 is offline   Reply With Quote
Old 01-26-2013, 08:15 PM   #3
Michael2000
Drives: .
Thanks, Austin.
It's a shame they left that on. I can't see any safety reason why, given it has the same tires, and even the same aerodynamic pieces. Maybe they didnn't want to stock another ECM.
Michael
Old 01-26-2013, 09:15 PM   #4
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Does the 1LE have the belly pan?
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 01-26-2013, 09:26 PM   #5
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
John B.
No
Sent from my DROID RAZR using Tapatalk 2
bannonm is offline   Reply With Quote
Old 01-26-2013, 09:36 PM   #6
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Originally Posted by Michael2000 View Post
Thanks, Austin.
Michael
The aero is different between them, I believe the 1LE still produces lift at speed the same as the SS and the ZL1 produces down force.
Old 01-26-2013, 09:41 PM   #7
Michael2000
Drives: .
I think you guys might of hit it. I saw an interview with the Camaro chief engineer on the web about the 1LE, and he said the ZL1 front splitter cancelled the extra lift from the wider front 1LE tires. Therefore, it would have the same lift as an SS.
Thanks.
Michael
Old 01-27-2013, 10:44 AM   #8
Russell James
Russell James's Avatar
Drives: two 5ths and a 1st
Plus, you don't have the power to go much above the SS speed limit. 5th gear will be effectively the same as an SS (taller in the trans, shorter in the diff) . Same power, same effective top gear, non MR suspension, no ZL1 aero package = no need to monkey with the speed limit, the car is going to top out just like an SS. Get above 140/150 ish without a lot more power and it takes forever to inch up more mphs. And be real floaty above 150ish. The ZL1 does it with supercharged power and aero and MR.... The 1LE is more aimed at road course action with the close ratio trans and handling tweeks.
Old 02-22-2013, 12:30 AM   #9
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Thanks.
Michael
"... the front splitter and the rear spoiler those are also to help with the grip on the track...
Cite:
Stop mis quoting and mis characterizing the Camaro and GM all over this forum, please. It is all you have done on all of your post is to bemoan everything about these cars and GM. What do you drive again?
Keep it up and people will begin to use the T word.
tramtwo is offline   Reply With Quote
Old 02-22-2013, 12:56 AM   #10
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
I thought the ZL1 convertible had a speed governor due to the convertible top/roof
Old 02-22-2013, 09:41 AM   #11
KKreme15
KKreme15's Avatar
Drives: C6 Z06
The ony camaro without the speed limiter is the ZL1 coupe
KKreme15 is offline   Reply With Quote
Old 02-22-2013, 10:43 AM   #12
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
My VIN = 2G1FK1EJ9A9105017
Old 02-22-2013, 02:13 PM   #13
gml1998
gml1998's Avatar
Drives: 2010 Synergy Green Camaro
Michael
All Camaros have a Governor , It's called the floorboard. LOL
gml1998 is offline   Reply With Quote
Old 02-22-2013, 02:59 PM   #14
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Yep, convertible has 155 limiter, just like my SS did, for a while
Smoked tail lights/ZL1-1LE 3rd brake
Rotofab cai
