02-04-2013, 05:10 PM | #1 |
Drives: CRT 2SS/RS L99 Join Date: Jul 2012
Removing Bowtie from heritage grill???
Does the Bowtie just pop out somehow? I started to pry on it alittle and I couldnt get it to budge and don't want to break anything. Whats the trick?
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2 |
02-04-2013, 05:17 PM | #2 |
Drives: . Join Date: Nov 2012
If it's attached like the factory grille, you have to pry really hard.
check this out http://www.phastekperformance.com/20...tie-delete.htm |
02-04-2013, 06:05 PM | #3 | |
Drives: 2012 1SS LS3 M6 black on black :) Join Date: May 2012
02-04-2013, 06:16 PM | #4 |
I have it attached to the heritage grill.
02-04-2013, 06:40 PM | #5 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
The whole assembly is held in by two screws from the back. I assume you are trying to remove the whole thing, landing pad and all.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
02-04-2013, 06:41 PM | #6 |
Drives: 13 1SS Vert, 05 Tahoe Z71, 67 RS/SS Join Date: Apr 2009
mine had the landing pad attached with a couple plastic nuts from the back.
02-04-2013, 06:43 PM | #7 |
Will the bowtie pop out so I can just take the pad off from the front?
02-04-2013, 06:45 PM | #8 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
The chrome bowtie separates from the black bowtie back piece. Get a thin knife between the chrome and black plastic, slowly work it out. It is just pushed in with several tabs. Then once the chrome bowtie is off, you will see the screws behind it.
If the grille bars are a little fubar'd from the mounting, stick something between the bars and leave it in the sun for a while it will straighten everything back out. |
02-04-2013, 06:58 PM | #9 | |
Drives: 2010 2SS/RS L99 IOM Join Date: Jan 2013
02-04-2013, 07:46 PM | #10 |
taking the bowtie off the heritage grill was a pain in the a$$ for me.
it helps to take off the metal cover that sits right where the hood latch is. you can probably reach your arm behind the grill without the cover. for me, i couldnt really get my arm behind the grill because i have large forearms. and i couldnt stick my fingers thru the grill either. in the end, i slid a flat head screw driver between the chrome emblem and plastic mount and pried it off. i worked around all 4 sides to slowly loosen each side. it probably took me 30 minutes of brute force to loosen the emblem from the plastic mount. it was a crude method but it worked. once the emblem was off, you can just unscrew the mount. |
02-04-2013, 08:50 PM | #11 |
I finally got the darn thing off. I was just afraid of breaking something.. thanks for the help
